Large hole saw developed for cutting mutilple-wall polycarbonate
May 07, 2018 - 08:45am
Peter E. Nuskey, a Southampton, Pa.-based mechanical consultant and custom machining veteran, wrote that he received a request for a 8.312"-dia. hole saw saw to cut holes in 1/4"-thick, multiple-wall polycarbonate. Saws this size are not commercially available, according to Nuskey.
He made one out of 3/4"-thick aluminum and a 1 1/4" bandsaw blade. The blade is held on the aluminum with pan head screws set at a 5° angle to pinch the blade into the corner of the rabbit in the aluminum disc.
"In this day and ago of micrograin carbide, diamond tooling and 800-ipm feed rates, sometimes solutions are found in old-school methods," Nuskey stated. "Try not to forget the methods our fathers used."
The hole saw produced a hole in 6 seconds. The previous method with a sabre saw would take 6 minutes.
He can be reached at (215) 355-3391.
  • bandsaw
    bandsaw
    Machine that utilizes an endless band, normally with serrated teeth, for cutoff or contour sawing. See saw, sawing machine.
  • bandsaw blade ( band)
    Endless band, normally with serrated teeth, that serves as the cutting tool for cutoff or contour band machines.
  • feed
  • sawing machine ( saw)
GROB Systems Inc., a developer of manufacturing systems and machine tools, has announced it will be hosting a Medical Technology event, together with industry partners Open0 Mind Technologies, Seco,…
03/28/2024
Mazak has joined major cybersecurity research universities and enterprises throughout the country as a collaborative partner with the Cybersecurity Manufacturing Innovation Institute.
03/26/2024
A pilot project for AI-based quality inspection has been successfully launched in the production unit in Šumperk, Czechia. The company said that the project has opened the door to achieving even…
