Product Showcase for May 2012
May 01, 2012 - 11:15am
J&M_Press Release-1.tif
RETENTION KNOBS. J&M Machine Inc. says its high-torque retention knobs increase tool life while enabling users to hold tighter tolerances by allowing a toolholder to properly mate with the spindle. By not expanding the small end of the toolholder, the holder is able to properly seat in the spindle and make full contact. That reduces harmonic vibration and tool runout. The retention knobs are reportedly suitable for all holders built to industry specifications. (800) 322-7750.
J&M Machine Inc.
www.jmmachineinc.com
Greenleaf_GSN100Best.tif
CERAMIC INSERTS. Greenleaf Corp.’s GSN100 ceramic insert grade is for machining cast iron. The grade is a blend of silicon nitride and toughening agents that extend tool life at cutting speeds up to 5,000 sfm when turning, grooving and milling, the company reports. Users can order GSN100 inserts with special geometries and application-specific edge preparations. (800) 458-1850.
Greenleaf Corp.
www.greenleafcorporation.com
Koma_khyan_1.tif
TOOL PRESETTER. Koma Precision Inc. offers Elbo Controlli’s Khyan tool presetting machine. The presetter is equipped with a twin-screen digital camera system and industrial PC architecture. The interchangeable spindle uses a one-piece cartridge, eliminating the need for adapters and the errors associated with their use, the company reports. Users can import and export DXF CAD profiles for detailed checking and comparison on the camera system. (800) 249-KOMA.
Koma Precision Inc.
www.komaprecision.com
WALTER-101B.tif
TURNING INSERTS. Walter USA LLC says its Valenite Tiger-tec Silver inserts boost productivity up to 75 percent when turning steel. A newly formulated Al2O3 coating and optimized microstructure resists plastic deformation and crater and flank wear. A silver flank face provides easier wear detection. The inserts are available in three grades (WPP10S, WPP20S and WPP30S) and four geometries (FP5 for facing and light cuts, MP3 for medium machining, MP5 for general machining and RP5 for roughing). (800) 945-5554.
Walter USA LLC
www.walter-tools.com/us
Abanaki_MightyMini09.tif
BELT SKIMMER. The Mighty Mini SST from Abanaki Corp. is a compact belt skimmer for part washers and machine tool coolant sumps. The stainless steel construction resists rust and corrosion in harsh environments. Its pull-out discharge trough is easy to clean and dual wipers enhance efficiency, according to the company. (440) 543-7400.
Abanaki Corp.
www.abanaki.com/222
Makino_a61nx.tif
HORIZONTAL MACHINING CENTERS. Makino Inc.’s a51nx and a61nx (pictured) horizontal machining centers accommodate large parts. The a51nx has a 22.0" X-axis travel, a 25.2" travel for the Y and Z axes and a total axis volume of 8.1 cu. ft. The standard a61nx has travels of 28.7", 25.6" and 31.5" in the X, Y and Z axes, respectively. An optional tall column on the a61nx extends the Y-axis to 28.7". The maximum tool length is 16.9" on the a51nx and 20.1" on the a61nx. (800) 552-3288.
Makino Inc.
www.makino.com
Sandvik_110984.tif
FIXTURING SYSTEM. The iLock fixturing system from Sandvik Coromant Co. securely clamps a solid-carbide endmill when machining ISO S materials, such as titanium. In some situations, axial forces pull a tool from its chuck despite the chuck’s high clamping force. To solve the problem, helical grooves are ground into the tool shank, and pin drivers mounted in the chuck prevent the tool from being pulled from the holder. This doesn’t increase tool runout, the company reports. (800) SANDVIK.
www.sandvik.coromant.com/us
Thinbit_designagroove B&W.tif
GROOVING TOOLS. Thinbit modifies its Design-A-Groove tools according to a customer’s specific application requirements. The company’s application engineers provide design assistance, price quotations and follow-up technical support. Special configurations include face grooving geometry, full or corner radius, increased DOC, chamfering, chip control and top rakes. Special toolholders can be ordered. (888) 844-6248.
Thinbit
www.thinbit.com
Eriez_Hydroflow 035.tif
FLUID RECYCLING EQUIPMENT. Eriez says HydroFlow fluid recycling and filtration equipment enables end users to cut metalworking fluid purchases 40 to 80 percent. The equipment removes tramp oils and solids, extending coolant and tool life and reducing bacteria in fluids. According to the company, the equipment also maximizes coolant effectiveness and longevity to improve productivity and reduce disposal costs. Machine-side and central systems are available. (888) 300-ERIEZ.
Eriez
www.eriez.com
VNE_Mini-V.tif
BORING, GROOVING and THREADING TOOLS. Vargus USA’s Mini-V indexable carbide inserts and toolholders are for boring, grooving and threading diameters from 8mm to 16mm. One toolholder accepts a variety of TiCN-coated inserts. The toolholders have 16mm-dia. shanks from 80mm to 130mm long and are made of alloy steel or carbide with steel seating. An insert clamping system improves vibration resistance, according to the company. (800) 828-8765.
Vargus USA
www.vargususa.com
Mastercam_Blade Expert (hi res).tif
MULTIAXIS PROGRAMMING. CNC Software Inc. says its Mastercam Blade Expert add-on simplifies the toolpath creation process for multiple-bladed parts, including fans, impellers, propellers and turbines. It eliminates guesswork and minimizes the need for extra geometry creation. It also minimizes unnecessary motion at the machine, resulting in an efficient and gouge-free toolpath that imparts a fine surface finish. The add-on enables users to remove material from between blades and finish the blades, floors and fillets. (800) 228-2877.
CNC Software Inc.
www.mastercam.com
TungstenToolworks_CTEttwProductShowcase.tif
CARBIDE SPECIALS. Tungsten Toolworks’ Web site enables users to design, quote and purchase custom carbide cutting tools to optimize machining efficiency for specific applications. Options include extended-reach necks, edge preparations and special coatings, such as TiB2 and diamond. The types of tools include microendmills, roughers, routers, drills, step drills and radius mills. (800) 854-2431.
Tungsten Toolworks
www.tungstentoolworks.com
Kaiser_319_SW.tif
BORING SYSTEM. BIG Kaiser Precision Tooling Inc.’s 319 SW twin-cutter boring system replaces 314 RW. By not introducing additional components or having to manually adjust insert height for different roughing methods, the 319 SW reduces setup time and eliminates the need for a presetter because of the fixed heights and diameter scale on the tool. Tool diameters range from 0.787" to 8.000" and the tools accept standard CC, SC and SP carbide inserts. (888) TOOL-PRO.
www.bigkaiser.com
BrushResearch_Composite Hub_AbrasiveNylon_ Wheels.tif
ABRASIVE NYLON BRUSHES. Brush Research Manufacturing Co. Inc.’s NamPower composite hub-wheel brushes are abrasive nylon brushing tools for deburring, surface finishing and edge radiusing. The brushes have indestructible cores, high filament density and balanced construction, the company reports. The flexible nylon filaments are set in a thermoplastic base and uniformly filled with silicon-carbide abrasive. The brushes are available in 6" and 8" diameters and have a 2" arbor hole. (323) 261-2193.
www.brushresearch.com
Cecor_Sump Sharkrelease2tif.tif
SUMP CLEANER. The 60-gal. Sump Shark from Cecor Inc. is for cleaning machine tool sumps in shops with limited space. The portable unit’s vertical design allows it to access tight spots and maneuver through crowded aisles and around corners. Fork pockets allow forklift transport. The air-operated venturi provides a pumping rate of 70 gpm. Two-way pumping enables a user to pump coolant back to the machine tool or transport it to a central recycling system after emptying the sump. (800) 356-9042.
Cecor Inc.
www.cecor.net
MitsubishiMaterials.tif
SHOULDER MILL. Mitsubishi Materials USA Corp.’s VOX shoulder mill is for machining cast iron and ductile iron. The tangentially mounted inserts create a strong cutting edge, the company reports. The fracture-resistant, grade-MC5020 inserts provide eight right-hand corners. Cutter diameters range from 2" to 10". Standard and fine-pitch teeth configurations are available. (800) 523-0800.
www.mitsubishicarbide.com
Komet_BASS_RollFormTap.tif
THREADING TOOLS. Komet of America Inc. added Bass machine taps and roll form taps to its line of threading tools. The tools are available in inch and metric sizes and made of HSS-E and HSS-E P/M. The taps reduce the cost per thread, maximize part quality and optimize the threading process, according to the company. (847) 923-8400.
www.komet.com
TechniforTFG20_SAMPLE1.tif
GANTRY LASER MARKING. Technifor’s latest laser marking product is the TFG20 gantry enclosure. The unit’s 12"×24"×6" table with X- and Y-axis numeric reference simplifies large-batch marking, according to the company. The 20w fiber laser marks a range of materials, including anodized ones. The company’s T8000 software is specific for gantry marking and compatible with most Windows operating systems. (704) 525-5230.
Technifor
www.technifor.us
SingleSource_slotworx.tif
MILLING CUTTERS. Single Source Technologies offers Pokolm Voha’s Slotworx milling cutters for roughing and finishing steel, aluminum, graphite, plastics and hardened materials. Tools are available for endmilling, facemilling, groove milling, pocketing and shoulder milling. The endmills have helical cutting edges with positive rake angles to provide continuous stability, enable easy cutting and impart fine surface finishes, according to the company. (877) 228-2884.
www.singlesourcetech.com
AMAMCO_1-Diamond Coated Router.tif
COMPRESSION ROUTERS. AMAMCO Tool offers compression routers for cutting various materials, including composites for aerospace applications. To eliminate delamination, the routers have advanced geometries for compression cutting action. A CVD diamond coating is grown on the carbide substrate to create a long-lasting surface. In a test for cutting distance, the company reports that its tool outperformed the nearest competitor by 55 percent. (800) 833-2239.
AMAMCO Tool
www.amamcotool.com
Okuma_GENOS M460-VE.tif
VERTICAL MACHINING CENTER. Okuma America Corp.’s GENOS M460-VE vertical machining center has a double-column structure to minimize floor space. The travels are 30", 18.11" and 18.11" in the X, Y and Z axes, respectively. The rapid-traverse rate is 1,574 ipm. The CNC machine comes standard with a 40-taper, 12,000-rpm spindle; 30/25-hp, variable-AC, liquid-cooled integral motor; and 32-position automatic toolchanger. (704) 588-7000.
Okuma America Corp.
oac.okuma.com/m460ve
Kennametal_KCU10-25.tif
TURNING INSERTS. Kennametal Inc. says its new Beyond insert grades boost productivity when turning difficult-to-machine alloys, such as titanium. Grade KCU10 is for OD and ID turning, grooving, plunging, undercutting and threading. Grade KCU25 is for threading, grooving, cutoff and selected additional turning applications. Both grades are PVD coated and receive a special surface treatment to improve performance when machining high-temperature superalloys. (724) 539-5000.
Kennametal Inc.
www.kennametal.com
JMSales.tif
THREADING TOOLS. J.M. Sales-USA (formerly JBO-USA) has added HSS-E and P/M application-specific taps from Hahnreiter Prazision to its product line. The company also supplies JBO thread mills, threading dies, thread gages and thread rolling tools. (248) 879-5984.
J.M. Sales-USA
www.jmsales-usa.com
EZ Burr small hole carbide hi-res.tif
DEBURRING TOOLS. E-Z Burr’s small-hole carbide series tools deburr the front and back of a hole in a single pass and deburr hole diameters as small as 0.125". Standard carbide tools from 0.125" to 2.0" and HSS tools from 0.040" to 2.0" are available. (800) 783-2877.
E-Z Burr
www.ezburr.com
Mikron_CrayzDrill Cool XL_Cover.tif
DEEP-HOLE DRILLS. Mikron Corp. Monroe offers CrazyDrill tools from 1mm in diameter for drilling 15, 20 and 30 diameters deep and from 2mm in diameter for drilling 40 diameters deep. The drills’ new cutting geometry produces short chips when cutting steel, enabling efficient evacuation, the company reports. The through-coolant drills reach full depth in a single stroke without pecking, allowing higher speeds and feeds. (203) 261-3100.
Mikron Corp. Monroe
www.mikron.com/tool-us
Carmex_Blu5sm.tif
THREADING INSERTS. Carmex Precision Tools LLC’s BLU-grade thread turning inserts combine submicrograin carbide with three layers of PVD coating. The strong, long-lasting tools create accurate threads and impart a fine surface finish even when cutting difficult-to-machine materials, according to the company. (888) 628-5030.
www.carmexusa.com
AbrasiveTechnology_SEAMLESS-WHEEL.tif
GRINDING WHEELS. Abrasive Technology uses its patented VFlex technology to consistently produce one-piece resin-bond diamond and CBN grinding wheels up to 12" wide. This ability increases wheel life up to 30 percent, reduces grinding cost per part compared to standard wheels, enables higher stock-removal rates and increases DOC, the company reports. Wheels are available up to 24" in diameter. (800) 964-8324.
Abrasive Technology
www.abrasive-tech.com
Monster Tool-HPNF series.tif
CARBIDE ENDMILLS. Monster Tool Co.’s HPNF carbide endmills are primarily for machining aluminum but are also suitable for other nonferrous materials. The endmills have a 45° helix angle to rapidly evacuate chips and a flute geometry that not only increases the chip load per tooth by 33 percent, but also improves workpiece finish and tool versatility, according to the company. The tools are available with two or three flutes and feature radii for extra edge strength. (888) 227-2433.
Monster Tool Co.
www.monstertool.com
Mil-Tec_HF2.5-4.tif
HIGH-FEED CUTTER. Mil-Tec says its high-feed cutter, tooled with standard Freedom inserts, achieves maximum efficiency. The positive cutting geometry of the ground and polished inserts enables high metal-removal rates and reduces power consumption. The cutter is available in shank and shell mill configurations and is reportedly ideal for use in medium-duty, 40-taper CNC machines. (800) 564-5832.
Mil-Tec
www.miltecusa.com
Doosan_NHM5000 4x5.tif
HORIZONTAL MACHINING CENTER. Doosan Infracore Machine Tools’ NHM5000 HMC accepts workpieces up to 33.5"×43.3". The machine’s one-piece casting provides a rigid base for the table and column, and the bed is made of fine-grain Meehanite to dampen vibration and dissipate heat. A 25-hp, two-geared motor powers the 6,000-rpm spindle. A refrigerated cooling system maintains a constant spindle temperature, regardless of ambient temperature or cutting conditions. (973) 618-2500.
www.doosaninfracore/machinetools.com
Methods_JobShopCell F Series.tif
AUTOMATION CELL. Methods Machine Tools Inc.’s JobShop Cell combines a Fanuc RoboDrill VMC and a Fanuc 6-axis robot for automated workpiece loading/unloading. The machine enables drilling, tapping and milling and processes virtually any part that fits in its 6" vise or chuck. The cell comes with inbound and outbound conveyors and guarding. The work-handling interface accommodates hydraulic and pneumatic workholders. (978) 443-5388.
www.methodsmachine.com
Fastenal_CT_images_May prdt write up.tif
TOOL VENDING MACHINES. Fastenal’s FAST CT vending machines provide 24/7 point-of-use access to individual round tools and inserts and produce detailed usage reports. The company provides the machines and restocks them, eliminating capital expense, paperwork and labor for the end user. Multiple machines can be located throughout a shop for enhanced productivity. (877) 265-8247.
Fastenal
www.fastenal.com
DMGMoriSeiki_MILLTAP_700.tif
MILLING AND BORING CENTER. DMG/Mori Seiki USA Inc.’s Milltap 700 is a vertical milling and boring center and represents Mori Seiki’s first joint development with DMG. The machine, which has a compact footprint, enhances efficiency because of its high speed and rapid tool changes, the company reports. (855) 364-6674.
www.dmgmoriseikiusa.com
Rush Model FC-250W Wheel Truing & Dressing Machine.tif
WHEEL TRUING AND DRESSING. Rush Machinery Inc.’s Model FC-250W machine is for truing and dressing flats, angles and radii on diamond and CBN grinding wheels, including single wheels and multiple wheel packs. The machine’s heavy-duty, one-piece cast iron base enhances rigidity and minimizes vibration, the company reports. The ExVision computer-driven vision system and software, an automatic power zoom and a 2-axis DRO for measurement are standard. (800) 929-3070.
Rush Machinery Inc.
www.rushmachinery.com
Zoller_genius_microsensor.tif
MICROGEOMETRY MEASUREMENT. Zoller Inc. has integrated a new microsensor with its >>genius 3<< inspection machine. The measurement system can be positioned via CNC over five axes, enabling touch-free measurement of tool geometries and scanning of different surfaces and work materials with exceptional precision and reproducibility, according to the company. (734) 332-4851.
Zoller Inc.
www.zoller.info/usa
  • abrasive
    abrasive
  • alloys
    alloys
  • arbor
    arbor
  • automatic toolchanger
  • boring
    boring
  • brushing
    brushing
    Generic term for a curve whose shape is controlled by a combination of its control points and knots (parameter values). The placement of the control points is controlled by an application-specific combination of order, tangency constraints and curvature requirements. See NURBS, nonuniform rational B-splines.
  • burr
    burr
  • centers
    centers
  • chamfering
    chamfering
  • chemical vapor deposition ( CVD)
  • chuck
    chuck
  • composites
    composites
  • coolant
  • cubic boron nitride ( CBN)
  • cutoff
    cutoff
    Step that prepares a slug, blank or other workpiece for machining or other processing by separating it from the original stock. Performed on lathes, chucking machines, automatic screw machines and other turning machines. Also performed on milling machines, machining centers with slitting saws and sawing machines with cold (circular) saws, hacksaws, bandsaws or abrasive cutoff saws. See saw, sawing machine; turning.
  • dressing
    dressing
  • endmill
    endmill
  • endmilling
    endmilling
    Operation in which the cutter is mounted on the machine’s spindle rather than on an arbor. Commonly associated with facing operations on a milling machine.
  • facemilling
    facemilling
  • flank wear
    flank wear
  • flutes
    flutes
  • gang cutting ( milling)
  • grinding
  • grooving
    grooving
  • helix angle
    helix angle
  • high-speed steels ( HSS)
  • inches per minute ( ipm)
  • inner diameter ( ID)
  • machining center
    machining center
  • metalworking
    metalworking
  • microstructure
    microstructure
    Structure of a metal as revealed by microscopic examination of the etched surface of a polished specimen.
  • milling
  • milling machine ( mill)
  • outer diameter ( OD)
  • physical vapor deposition ( PVD)
  • plastic deformation
    plastic deformation
    Permanent (inelastic) distortion of metals under applied stresses that strain the material beyond its elastic limit.
  • rake
    rake
  • shank
    shank
  • superalloys
    superalloys
  • tapping
    tapping
  • thread rolling
    thread rolling
    Chipless, cold-forming material-displacement process where a rolling head is pressed into the workpiece to create threads. The material is stressed beyond its yield point, which causes it to be deformed platically and permanently. There are three basic types of rolling heads: axial, radial and tangential.
  • threading
    threading
  • toolchanger
    toolchanger
  • toolholder
    toolholder
  • toolpath( cutter path)
  • truing
    truing
    Using a diamond or other dressing tool to ensure that a grinding wheel is round and concentric and will not vibrate at required speeds. Weights also are used to balance the wheel. Also performed to impart a contour to the wheel’s face. See dressing.
  • turning
  • vision system
    vision system
  • web
    web
