Creeping Ahead
Author Chris Stine
June 01, 2007 - 12:00pm
Replacing milling and broaching with creep-feed grinding. Why more shops have replaced milling and broaching with creep-feed grinding.
Read the Full Article
  • broaching
    broaching
    Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
  • creep-feed grinding
    creep-feed grinding
    Grinding operation in which the grinding wheel is slowly fed into the workpiece at sufficient depth of cut to accomplish in one pass what otherwise would require repeated passes. See grinding.
  • gang cutting ( milling)
  • grinding
  • milling
Author
Vice President
Chris Stine is vice president of United Grinding Technologies Inc., Miamisburg, Ohio. Contact him at (937) 847-1215 or by e-mail: chris.stine@grinding.com. United Grinding is the North American arm of Körber Schleifring and has two main offices. The company’s factory in Fredericks-burg, Va., handles EWAG and Walter tool grinders and measuring machines, while a factory in Miamisburg sup-ports Studer, Blohm, Jung, Mägerle, Schaudt and Mikrosa cylindrical and profile grinders. For more informa-tion, visit www.grinding.com.
