Ultrason milling machine for hard, brittle materials
Published Date
October 17, 2025
The ULTRASONIC 60 Precision
The Ultrasonic 60 Precision machine from DMG MORI offers a cost-effective entry into the precision machining of hard, brittle materials such as silicon carbide, Zerodur, and hard metals.
The ultrasonic milling machine features a monolithic machine bed, solid castings, and wide roller guide rails that the company says gives it outstanding rigidity. Precision cooling of the linear guides is standard equipment and ensures high accuracy and process stability.
The positioning accuracy of the Ultrasonic 60 Precision is 5 µm, and the accuracy of the circular interpolation is 6 µm. The process stability and high accuracy of the Ultrasonic 60 Precision go hand in hand with enormous machining versatility. The swivel rotary table of the 5-axis machining center can carry workpieces weighing up to 300 kg and has a swivel range of -35° to +110°. 60 tools are available as standard. A tool magazine with 120 slots is available as an option.
The Ultrasonic 60 Precision thus machines complex components productively and economically, the company says.
  • gang cutting ( milling)
  • interpolation
    interpolation
  • machining center
    machining center
  • milling
  • milling machine ( mill)
  • precision machining ( precision measurement)
    Machining and measuring to exacting standards. Four basic considerations are: dimensions, or geometrical characteristics such as lengths, angles and diameters of which the sizes are numerically specified; limits, or the maximum and minimum sizes permissible for a specified dimension; tolerances, or the total permissible variations in size; and allowances, or the prescribed differences in dimensions between mating parts.
