- abrasive
abrasive
- coolant
- cubic boron nitride ( CBN)
- dressing
dressing
- grinding
- grinding wheel
grinding wheel
- straight oil
straight oil
Cutting fluid that contains no water. Produced from mineral, vegetable, marine or petroleum oils, or combinations of these oils.
- swarf
swarf
- tolerance
tolerance
- total indicator runout ( TIR)
Combined variations of all dimensions of a workpiece, measured with an indicator, determined by rotating the part 360°.
- truing
truing
Using a diamond or other dressing tool to ensure that a grinding wheel is round and concentric and will not vibrate at required speeds. Weights also are used to balance the wheel. Also performed to impart a contour to the wheel’s face. See dressing.
In addition to TIR (total indicator runout) is the dimension of the grinding wheel side flutter, runout, roundness and tolerance. This is accomplished by truing, dressing, forming and conditioning.
Conventional and ceramic precision abrasive grinding wheels are trued by diamond single points, hand-set diamond clusters, diamond form blocks or rolls, blade tools, or any other means of truing, to bring the precision abrasive grinding wheel surface to within 0.0005" TIR straight and formed.
The same goes for diamond grinding wheels. CBN grinding wheels are different. They must be trued to within 0.000040" TIR straight or with a form. The reason being is that in precision grinding hard metals the swarf becomes threadlike chips and can only be made to grind correctly if the fine metal threads are formed consistently. This requires a lubric grinding coolant (8:1 mix) or with straight oil. Keep your infeeds in dressing down below 0.001" to avoid crushing the bonds.
Diamond coated dressing blocks have been designed for optimal performance on conventional and ceramic grinding wheels. Ideal for roughing and finish dressing.
A PB1 diamond-coated dressing block is 1" square for truing abrasive wheels 8" in diameter and smaller. (Shown)
An RB1 diamond-coated dressing block is 1 1/2" in diameter for truing abrasive wheels 8" diameter and larger.
