A tipping point for tapping
May 21, 2018 - 03:15pm
Wilhelm Becker GmbH & Co. KG
As discussed in the current issue of Cutting Tool Engineering magazine in the feature article “Specialization on tap,” material-specific taps continue to evolve.
Sources anticipate increasing specialization of the materials used for taps across industries.
“I think stuff like carbon steel and tool steel is going to be around forever, but that market share will decrease,” said Applications Engineer Alec Janson at OSG USA Inc., which is headquartered in Irving, Texas. “The range of applications where general-purpose taps will be useful likely will diminish.”
However, he said demand for commodity tooling remains very high and may stay that way for some time, at least until advances in materials drop demand from “very high” to merely “high.”
“Commodity tooling will still be used in more common materials and lower-volume applications,” he said.
Commercially advanced materials, including polymers and “strange” composite metals, increasingly serve specific applications, Janson said. As an example, he cited the slow trend in automobile engines to transition from big, steel blocks to aluminum ones.
“That’s a big change for automotive companies and a big change for us in tapping,” he said. “We’ll see transitions like that happen in other industries. I don’t know what the material will be, but we’ll do the best we can to figure out how to produce tooling that will assist in that material.”
For more information about where tapping is headed, read the article.
  • tap
    tap
  • tapping
    tapping
04/16/2024
04/15/2024
