Rollomatic and Strausak host open house event
October 11, 2021 - 06:30am
Rollomatic and Strausak will be presenting a biennial OpenHouse in Mundelein, Illinois, on November 9-11, 2021. The event is a repeat of previous OpenHouse events where typically more than 130 end‐users from more than 25 US states, Mexico, and Canada experience the latest in Rollomatoc Group technology, attend learning sessions, and get key answers for precision production needs.
In line with previous years, Rollomatic will have travel & overnight arrangements available for attendees as follows:
  •  Travel vouchers per person for up to 2 people.
  •  One free night a local hotel up to 2 rooms.
  •  Free transportation to/from Chicago O’Hare airport and the hotel.
  •  Free lunches and dinners.
This biennial event offers current & prospective end‐users of grinding and laser curing equipment the opportunity to see the entire line of Rollomatic Group products as well as new technology with:
  •  New Rollomatic 660XW model hybrid tool and peel grinding machine.
  •  New Strausak ONE cost‐effective 5‐axis adaptive tool grinding machine (new‐generation linear) with modular options.
  •  GrindSmart ‐ Several 5‐ and 6‐axis Rollomatic tool grinding machines.
  •  ShapeSmart ‐ Several Rollomatic pinch and peel grinding machines.
  •  LaserSmart ‐ Laser cuttng machine including ablation and 3D machining of PCD and other super‐hard materials.
  •  Platit surface coating equipment.
  •  Zoller Genius measuring machine.
  •  SmartFactory presentation.
To sign up for the event, visit https://cvent.me/lz1DG2
  • grinding
  • grinding machine
    grinding machine
04/15/2024
04/11/2024
