Surface finish on A36 steel
Author John Saunders
October 27, 2020 - 10:45am
A 36 steel is not a particularly difficult material to machine. However, it can be challenging to achieve an exceptional surface finish, especially when a part calls for a 63.5 mm (2.5") axial depth of cut. The challenge for this ProvenCut recipe was to achieve an acceptable — or even excellent — finish with a tool length-to-diameter ratio of 5-1.
The larger a tool is, the stiffer it is. But large-diameter carbide cutting tools present problems. The cost goes up drastically. A 19.05 mm (0.75") tool may cost over twice the price of a 12.7 mm (0.5") tool — and rightfully so, as the former has 2.3 times the amount of carbide. For that reason, large-diameter endmills rarely are purchased or kept in inventory as frequently as smaller-diameter ones. Setting aside tool price, larger-diameter endmills also create more tool pressure, making them difficult to run on many common 40-taper machining centers.
A key to this recipe was finding a stiff 12.7 mm dia. endmill. That’s right: The diameter of an endmill isn’t the only factor in determining the stiffness of a cutting tool. The higher a flute count is, the thicker the core of a cutting tool is. However, higher flute counts must be balanced with increased tool pressure, which can lead to chatter due to more points of contact with raw material.
ProvenCut recipe 586 struck a wonderful balance, machining a piece free of chatter and yielding an extraordinary finish using a YG-1 V7 PlusA six-flute endmill held in a Lyndex-Nikken SK16 collet holder. The 2D contour finishing operation was programmed with Autodesk Fusion 360 and run at 210 m/min. (690 sfm) at 0.015 mm feed per tooth (0.0006" feed per tooth) with a 0.203 mm (0.008") radial DOC and 63.5 mm axial DOC.
To view a video of machining A36 steel at www.ctemag.com,  enter this URL on your web browser: cteplus.delivr.com/2gpv6
  • centers
    centers
  • chatter
    chatter
  • collet
    collet
  • depth of cut
    depth of cut
  • endmill
    endmill
  • feed
  • stiffness
    stiffness
  • web
    web
Author
John Saunders owns and operates Saunders Machine Works, a manufacturer of machine shop tools and fixture plates. He documents his machining and entrepreneurial endeavors on the YouTube channel NYC CNC and is founder of ProvenCut, a website with a video library of speeds and feeds.
