- dressing
dressing
- grinding
- grinding machine
grinding machine
Grinding machine operators are able to listen to the processes via acoustic emission (AE) monitoring systems and use the information to shorten cycle times and minimize wheel loss from dressing. But, AE sensors need to be positioned to deal with interfering background noise.
