Give CNC lathes an uptime makeover
Author Kip Hanson
August 01, 2013 - 10:30am
I once thought nothing of boring a new set of top jaws. Just remove half a dozen cap screws, take the old jaws out, bolt on fresh jaws, attach a spider or boring ring and crank the hand wheel until the part fits. Setups were long in the 1980s and my boss considered 2 or 3 hours of downtime each day a normal cost of business.
Today, shops might opt for a quick-change chuck. Simply twist a few screws and load a new set of top jaws. And, compared to the hours of lost production in the prehistoric days of paper tape and brazed carbide cutting tools, dropping eight to 10 grand for a quick-change chuck is a no-brainer.
centroteX%20action.tif
All images courtesy Hainbuch America
Swapping a Centrotex chuck takes under a minute, and is guaranteed to 5µm runout and repeatability, according to Hainbuch America.
HB013273.tif
Exploded view of Hainbuch’s TOPlus collet system together with a Centrotex masterplate.
But because of different workholding requirements, sometimes even a quick-change chuck can’t cut the mustard. Collet chucks, faceplates and expanding mandrels are just some of the other workholders found in most turning departments, and swapping one out means muscling 20 lbs. or more of an uncooperative steel chuck out of a CNC lathe before mounting whatever workholding device stands at bat next. This is a something that even the speediest setup man needs 20 minutes to accomplish.
“Our industry has worked extremely hard over the last 20 to 30 years to take minutes or even seconds out of cycle time. What we didn’t do is figure out how to take minutes and hours out of changeover time,” said Jeff Estes, director of Partners in THINC Technology Centers for machine tool builder Okuma America Corp., Charlotte, N.C.
Because customers demand products with short lead times and single-digit lot sizes, the time it takes to set up a machine frequently exceeds the time needed to machine the parts. Estes said: “For a lot of our customers, their first part is their only part. They are making extremely difficult, challenging parts. Production output is always going to be based on the weakest link in your system, and that is typically the setup.”
Hainbuch America Corp., Germantown, Wis., addresses this weakest link with its Centrotex quick-change workholder. Guri Singh, Hainbuch’s CNC production manager, said: “Centrotex is a way to quickly change the entire chuck, rather than just the jaws themselves. It works off a pair of male and female tapers separated by precision ball bearings. Similar to the way a Sandvik Coromant Capto system works, everything is manufactured in such a way that the deformation of those three components is very precisely controlled, giving you extremely rigid clamping together with accuracy. It’s a mechanism difficult to manufacture but very simple and robust to use.”
For shops looking to reduce setup times, Singh outlined some elements of an effective workholding system. The first is R and R. No, this doesn’t mean a 3-day weekend at the lake. “Runout and repeatability are critical,” he said. “We like to see 5µm or better for both, measured radially as well as axially.”
With this accuracy, Singh said shops can avoid “dialing in” the chuck after mounting or taking a skim cut to true up the jaws. “You should be able to slap it on, tighten it down and go.”
Another important feature in a quick-change chuck is interoperability. Switching from one brand’s 3-jaw chuck to its collet chuck in a minute flat is swell, but switching from brand A’s 3-jaw chuck to brand B’s collet chuck to brand C’s expanding mandrel is better than chocolate cake on your birthday. “In a Centrotex environment, each machine is equipped with a permanent master plate,” Singh said. “Each workholding device you wish to quick-change among those machines is then adapted to that master via a matching plate.”
Flexibility like this means shops can use their existing workholding on any machine in the shop, within reason. “You need a system that will let you grip a part on your 2-axis lathe, then move that same part together with the workholding to a 3-axis machining center with little or no repositioning error or compromised rigidity,” Singh said.
This last point is what separates the men from the boys in the world of quick-change. If you’re looking to keep your CNC moneymakers turning, make fixtures offline. “One of the big markets for a quick-change system such as the Centrotex is in shops with multifunction machines,” Singh said. “You don’t want to take a Mori-Seiki NT or an Okuma Multus offline to bore a set of chuck jaws. That’s why it’s important to buy a quick-change system that lets you prepare workholding on a less expensive machine, an engine lathe, for example, then bring it to the production floor when you’re ready to changeover.”
Singh said shops throw a lot of money at new machines but almost none toward workholding. “Workholding is a boring topic. You go to a tool show and the CNCs are the most entertaining things there. Machine builders do a good job of promoting their speed and accuracy, tool capacity, power, what have you, and customers eat that stuff up.”
While U.S. manufacturing is now dominated by low-volume, high-value products made of difficult materials, about 70 to 80 percent of customers do all turning operations on the standard 3-jaw chuck that came “free” with the machine, according to Singh.
That leaves a lot of room for improvement. When you switch to the optimal clamping device for a given operation, you’ll see a noticeable improvement in cutting performance, tool life and surface finish. A quick-change workholding system takes the pain out of switching to the ideal device at will. Less downtime, higher cutting data, longer tool life, better part quality. These are all upsides that dramatically affect return on machine tool investment.
Being competitive means paying attention to boring details. Get a modular, quick-change workholding system. Your bottom line will thank you. CTE
About the Author: Kip Hanson is a contributing editor for CTE. Contact him at (520) 548-7328 or khanson@jwr.com.
  • boring
    boring
  • centers
    centers
  • chuck
    chuck
  • collet
    collet
  • flat ( screw flat)
    flat ( screw flat)
  • lathe
    lathe
  • machining center
    machining center
  • mandrel
    mandrel
    Workholder for turning that fits inside hollow workpieces. Types available include expanding, pin and threaded.
  • multifunction machines ( multitasking machines)
    Machines and machining/turning centers capable of performing a variety of tasks, including milling, drilling, grinding boring, turning and cutoff, usually in just one setup.
  • turning
Author
Contributing Editor
520-548-7328
