Clamp tricks for milling
Author Brandt Taylor
September 07, 2021 - 02:45pm
T-slot clamps are tried-and-true accessories for milling applications — so much so that if you have a milling machine, chances are that you have a set of T-slot clamps. Besides clamping, these clamps can be used to set up work stops and fixturing, which I’ll get to in this article.
These clamps generally are used to clamp a workpiece to a machine table for machining. Standard sets include studs of various lengths with special nuts that fit into milling machine table T-slots and heavy-duty hex nuts to hold down the associated clamps. The clamps are different lengths and are used with riser blocks that have steps to allow the clamps to be positioned at assorted heights from the machine table surface. T-slot nuts are applied with studs of varying length or T-slot bolts of varying length with clamps and step blocks to set the clamp at the appropriate height for the workpiece.
Step blocks are available with thicknesses of 25.4 mm (1"), 38.1 mm (1.5") or 50.8 mm (2"). When using a clamp setup consisting of a clamp with one end resting on a standard 25.4-mm-thick step block, employing a large-diameter flat washer under the step block is convenient. The washer assures stability of the block when it straddles a T-slot. A flat washer for a 25.4 mm bolt with an outside diameter of 63.5 mm (2.5") works well with standard step blocks.
Two setups are shown using standard T-slot hardware with pieces of steel tubing used as risers.  Image courtesy of B. Taylor
The T-slot clamps also can be used as work stops. For example, if a workpiece is held with a milling vise, it might be useful to have a work stop at some distance from the vise. The photographs show two such setups using standard T-slot hardware with pieces of steel tubing used as risers. The tube sets the vertical height of the clamp, and the nose of the clamp is utilized as the work stop. Simply place the workpiece where you want it, touch the nose of the clamp against the workpiece, tighten the clamp nut, and you have it.
This method can be used to make a very rigid stop. When working with heavy workpieces on a milling machine, it’s nice to use a work stop that doesn’t move or deflect from being bumped by a workpiece. Larger-diameter tubing with a longer clamp makes a more rigid stop. In the photo with the smaller-diameter tube, note the flat washer under the tube. Use 4.7625 mm (0.1875") wall or heavier tubing. The bigger setup uses an 88.9 mm (3.5") outer diameter × 9.525 mm (0.375") wall tubing with a 152.4 mm (6") long clamp. The smaller setup applies a 31.75 mm (1.25") OD × 4.7625 mm wall tubing with a 101.6 mm (4") long clamp.
Or maybe a job requires a workpiece to be clamped to a table or on risers so cutting tools can pass through, and there are a few parts to make. Two or three clamps can be set around the workpiece to make quick, easy fixturing. In that case, it’s handy to have a few pieces of 50.8-mm-long threaded rod that fit the clamping nuts so clamps can be bolted right to the table.
My shop makes components for industrial machinery, so steel tubing is used from time to time. That is a good reason to hold on to bits of tube. I hope that this column is useful out there.
  • flat ( screw flat)
    flat ( screw flat)
  • gang cutting ( milling)
  • milling
  • milling machine ( mill)
  • outer diameter ( OD)
  • outer diameter ( OD)2
