- dressing
dressing
- grinding
- truing
truing
Using a diamond or other dressing tool to ensure that a grinding wheel is round and concentric and will not vibrate at required speeds. Weights also are used to balance the wheel. Also performed to impart a contour to the wheel’s face. See dressing.
Truing and dressing grinding wheels can give operators a rough time if they're not up-to-speed on the processes' particulars.
