3D Printing, To Infinity and Beyond
An October 2016 Look Ahead piece takes a sidelong look at 3D printing.
October 15, 2016By Michael C. Anderson
Bleacher philosophers have long noted a distinction that baseball has from other sports: Where the gridiron and the basketball court are rectangular spaces that completely circumscribe the area of play, the baseball field extends, in at least one direction, to infinity. A ball hit between first and third, and the fielder chasing it, could, in theory, travel any distance and be in play.
That poetry of open space is evoked by the Infinite-Build 3D Demonstrator additive-manufacturing (AM) system from Stratasys Ltd., developed with input from Boeing and Ford for large-part production in custom OEM and on-demand aftermarket applications.
The Infinite-Build addresses the requirements for large, lightweight, thermoplastic parts with repeatable mechanical properties. Its novel approach to FDM (fused deposition modeling) extrusion, according to Stratasys, increases throughput and repeatability.
With traditional 3D printers, the printer head moves horizontally, adding layer upon layer so that the printed object grows vertically. The Infinite-Build turns that concept on its side. The Z-axis is oriented vertically so printing occurs sideways. Instead of building up, it builds out—completely out.
View print ads from this spread
Review the ads on this magazine spread to continue reading. Each ad takes two seconds; a two-page ad counts once.
Advertisers on this magazine spread
Print placements on this magazine spread
Kyoceraprecisiontools
DRA Magic Drill
High Efficiency Modular Drill Excellent Hole Accuracy Every Time Designed for optimal web thickness, the DRA Magic Drill limits deflection and finely breaks chips for smooth deep hole cutting that creates clean, round holes every time. Featuring a low cutting force design, the special chisel edge with S-curve reduces thrust force and.
DRA Magic Drill High Efficiency Modular Drill Excellent Hole Accuracy Every Time Designed for optimal web thickness, the DRA Magic Drill limits deflection and finely breaks chips for smooth deep hole cutting that creates clean, round holes every time. Featuring a low cutting force design, the special chisel edge with S-curve reduces thrust force and controls vibration for excellent hole accuracy. Easy insert replacement without removing any screws!
Print page 91
Visit Kyoceraprecisiontools View this placement in the issue record
As new layers are added to the print at one end, the other end—what would have been the bottom if the Z-axis was horizontal—moves toward the back of the machine in 1″ (25.4mm) increments. When the print reaches the back of the machine, it just keeps going. The back is open (though protected by thermal curtains to control cooling), and as long as support is supplied to the emerging print and build material is supplied to the printer, the print can keep getting longer.
Boeing is using an Infinite-Build 3D Demonstrator to explore the production of low-volume, lightweight parts. Ford is also exploring manufacturing applications for this AM system. Stratasys believes the design will prove to be a home run.
For more information about Stratasys, Eden Prairie, Minn., visit www.stratasys.com or call (800) 801-6491.
The Stratasys Infinite-Build 3D Demonstrator builds parts of unlimited length. Image courtesy Stratasys.
  • mechanical properties
    Properties of a material that reveal its elastic and inelastic behavior when force is applied, thereby indicating its suitability for mechanical applications; for example, modulus…
