Products
Latest Products
LK Metrology integrates Renishaw REVO into CAMIO 2026
Product November 18, 2026
LK Metrology has released CAMIO 2026 R1, adding support for Renishaw’s REVO 5-axis scanning probe system to its coordinate measuring machine programming, analysis and reporting software. Users can program and execute REVO inspection routines directly in CAMIO, including sweep scanning and head-touch strategies.
LMT Tools adds WPR-AP indexable insert for finishing
Product November 17, 2026
LMT Tools has introduced the WPR-AP indexable insert from its CopyLine range for finishing and semifinishing operations. The LMT Kieninger insert uses a ball-shaped copying edge, LCHK05M cutting material and Nanomold Red³ coating. LMT Tools positions the insert as an alternative for finishing applications otherwise using solid carbide tools.
Sandvik Coromant extends CoroDrill Dura 462 range to deep-hole drilling
Product November 14, 2026
Sandvik Coromant has expanded its CoroDrill Dura 462 family with solid carbide deep-hole drills for applications from 12×D to 30×D. The drills combine grade X2BM, Zertivo 2.0 PVD coating and a micro-grained carbide substrate for multi-material drilling. The geometry incorporates a refined flute design, offset double margins, double gashes, blended root radii and a 135-degree point angle.
Star Cutter integrates tracking and secondary processes in flexible automation cell
Product November 12, 2026
Star Cutter’s Flexible Automation Cell combines automation hardware, software and secondary processes in a connected grinding workflow. The platform can be integrated across multiple CNC grinding platforms to address different production requirements. An RFID reader identifies and tracks parts as they move through the cell.
Sandvik Coromant launches CoroThread Mill 500 for internal threading
Sandvik Coromant has launched CoroThread Mill 500, a solid carbide orbital thread mill for internal threading of blind and through holes. The product family succeeds CoroMill Plura R217. The tools address deep threads, long overhangs, difficult materials and unstable setups. Features include hard-substrate grades, optimized geometry, PVD coatings and chatter-free technology in selected variants.
Fixtureworks adds QLSWM mini spring swing clamps
Product November 10, 2026
Fixtureworks has expanded its workholding lineup with QLSWM mini spring swing clamps for vertical clamping of small and scratch-sensitive workpieces. The clamps are available with clockwise or counterclockwise locking motion. Their compact design measures up to 30 mm long and 16 mm wide, with clamping force up to 2.5 lb., according to the company.
Sandvik Coromant combines barrel and ball-nose geometries for complex profiling
Product November 9, 2026
Sandvik Coromant has introduced CoroMill Plura barrel conical, a two-in-one solid carbide tool that combines barrel and ball-nose geometries for multi-axis profiling of complex components such as blisks and blades. The geometry enables manufacturers to machine fillets, flanks and complex surfaces in a single setup.
USB and RJ45 fitted sockets for mechanical engineering and automation
Product October 30, 2026
The norelem firm is expanding its range with compact fitted sockets for USB and RJ45 connections to more easily integrate common data interfaces into housings, switchboxes, control panels and other applications. Different connection variants and designs offer flexibility for different installation situations.
Custom solutions for machining center tooling
Product October 26, 2026
Platinum Tooling now offers custom machining center tooling solutions, designed around the unique requirements of each application. From modifications to existing tooling to completely new designs, Platinum Tooling says its team combines precision, expertise and application-focused engineering to solve challenging tooling needs.
Fiber discs for carbon steel applications
Product October 21, 2026
Saint-Gobain is extending its popular Norton RazorStar product line with the non-supersized FS1190 Fiber Discs that the company says deliver fast stock removal, cooler cutting action, and extended product life. Engineered for use in welding, metal fabrication, MRO, construction, and oil and gas, these new fiber discs feature the same patented, engineered shaped ceramic grain technology and geometry as the original RazorStar.
1 2 3 … 751
