Walter to feature expanded cutting tool line at Eastec
April 04, 2023 - 08:00am
Prototyp brand Advance and Supreme line solid carbide end mills:
Walter, the Greer, S.C.-based cutting tool manufacturer, will showcase its latest technologies at EASTEC ’23. The show in West Springfield, Mass., runs from May 16-18.
Walter offers a range of precision tools for milling, turning, drilling and threading applications. In addition, the company says it works together with its customers to develop optimum solutions for fully machining components for use in the aerospace industry, as well as automotive, energy, and general engineering.
The Walter exhibit will feature an expansion to the Prototyp brand Advance and Supreme line of solid carbide end mills:
  • Over 3000 new inch-size products
  • Full line of applications and materials:
    --Heavy cuts, deep slotting, long axial depth profiling, 5-axis cavity work
    --Advance line for Steel, Stainless, and Cast Iron
    --Supreme line for Titanium and Nickel base alloys
    --Advance line for Aluminum and Lightweight materials
In addition to the new end mill line, the Walter exhibit will also feature:
  • Walter Blaxx family of high-performance indexable milling cutters
  • Walter Cut SX grooving system, with self-gripping, form-locking indexable inserts that provide ideal cutting force for the tool
  • New Tiger·tec Gold high-performance cutting material for steel milling, turning and drilling
Also featured will be Walter’s expansion to its range of tough, reliable and long-life standard solid carbide deep-hole drills
Further, the company will feature its new range of Walter counterboring and precision boring tools for diverse machining applications.
The exhibit will also demonstrate the Walter Online catalog and its tool-specific search capabilities, Walter GPS to find optimum machining solutions.
  • alloys
    alloys
  • boring
    boring
  • counterboring
    counterboring
    Enlarging one end of a drilled hole. The enlarged hole, which is concentric with the original hole, is flat on the bottom. Counterboring is used primarily to set bolt heads and nuts below the workpiece surface.
  • cutting force
    cutting force
  • gang cutting ( milling)
  • grooving
    grooving
  • milling
  • milling machine ( mill)
  • profiling
    profiling
  • slotting
    slotting
    Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
  • threading
    threading
  • turning
04/16/2024
04/15/2024
