USCTI launches new website
March 15, 2016 - 07:00pm
The United States Cutting Tool Institute (USCTI), the leading trade association for the North American cutting tool industry, is pleased to announce the launch of its new Website, http:www.uscti.com. The redesigned website is mobile-friendly, and with simplified navigation, makes it easier to find membership information, technical resources, benefits of USCTI membership and a comprehensive membership directory.
USCTI members represent ten product divisions (Carbide Tooling, Drill & Reamer, Metal Cutting Saw Blades, Milling Cutter, Polycrystalline Diamond & Polycrystalline Cubic Born Nitride (PCD & CBN), Substrate Materials, Surface Coating, Tool Holder and All Other Tooling). The site has been designed to easily identify the types of products member companies manufacture.
The Website includes monthly press releases highlighting U.S. cutting tool consumption and is a great resource to learn more about upcoming meetings, USCTI sponsors and the resources that are available in the Technical Resource Center. For those companies interested in membership in USCTI, with the newly designed navigation, membership information is a click away.
  • gang cutting ( milling)
  • milling
  • milling cutter
    milling cutter
  • reamer
    reamer
  • sawing machine ( saw)
