Tool-Flo expands product line
December 11, 2013 - 06:00pm
Tool-Flo expands product line.
Threading and grooving toolmaker Tool-Flo Manufacturing, Houston, has added polycrystalline diamond (PCD) and polycrystalline cubic boron nitride (PCBN) tools to its product line. The ultrahard materials allow for longer tool life when cutting abrasive materials such as graphite, hard rubber, plastics, carbon, fiberglass components, ceramics, wood, copper, bronze, brass and aluminum alloys, and permit higher removal rates and faster cycle times.
Tool-Flo uses laser machining in addition to diamond grinding and wire EDMing to make its PCD and PCBN tools. Laser machining provides an unmatched cutting edge quality which will, in turn, provide excellent surface finish and longer tool life, according to Tool-Flo. Laser can also  cut special chip breakers in any PCD cutting tool. While Tool-Flo currently uses laser machining only on its PCD and PCBN tools, it plans to use it on carbide inserts in the future.
  • abrasive
    abrasive
  • alloys
    alloys
  • aluminum alloys
    aluminum alloys
    Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wrought compositions and casting compositions. Some compositions may contain up to 10 alloying elements, but only one or two are the main alloying elements, such as copper, manganese, silicon, magnesium, zinc or tin.
  • ceramics
    ceramics
  • cubic boron nitride ( CBN)
  • grinding
  • grooving
    grooving
  • laser machining
    laser machining
    Intensified, pulsed beams of light generated by lasers—typically carbon dioxide or neodium-doped yttrium aluminum garnet (Nd:YAG)—that drill, weld, engrave, mark, slit and caseharden. Usually under CNC, often at both high cutting rates (100 linear in./sec.) and high power (5kW or more). Lasers also are used in conjunction with in-process quality-control monitoring systems allowing measuring accuracies of 0.00001".
  • polycrystalline cubic boron nitride ( PCBN)
    Cutting tool material consisting of polycrystalline cubic boron nitride with a metallic or ceramic binder. PCBN is available either as a tip brazed to a carbide insert carrier or as a solid insert. Primarily used for cutting hardened ferrous alloys.
  • polycrystalline cubic boron nitride ( PCBN)2
  • polycrystalline diamond ( PCD)2
  • threading
    threading
Mazak has joined major cybersecurity research universities and enterprises throughout the country as a collaborative partner with the Cybersecurity Manufacturing Innovation Institute.
03/26/2024
A pilot project for AI-based quality inspection has been successfully launched in the production unit in Šumperk, Czechia. The company said that the project has opened the door to achieving even…
03/22/2024
Hypertherm Associates to award Powermax systems to 12 North American schools as part of Spark Something Great grant program.
