- conventional milling ( up milling)
Cutter rotation is opposite that of the feed at the point of contact. Chips are cut at minimal thickness at the initial engagement of the cutter’s teeth with the workpiece and increase to a maximum thickness at the end of engagement. See climb milling.
- feed
- metal-removal rate
metal-removal rate
- toolholder
toolholder
Toolmaker OSG Corp. and toolholding manufacturer Haimer GmbH signed a strategic partnership and licensing agreement in which the OSG-Group's round endmills will include Haimer's Safe-Lock system.
The Safe-Lock design in cutting tools and toolholders combines a press fit clamping with a positive form locking mechanism. This prevents round cutting tools from being rotated or completely pulled out from a toolholder during heavy machining, according to the company. The combination of symmetrical pull-out protection, high concentricity and excellent balance results in a vibration-free machining process, which the company said leads to a more efficient metal-removal rate when compared to conventional milling chucks or Weldon-shank cutting tools and toolholders.
"Our field testing proved that the combination of our endmills with Safe-Lock resulted in higher rpms and feed rates even with difficult-to-machine materials," explained Jiro Osawa, technical managing director at OSG headquarters and CEO for North America. "This enables our customers to obtain a significant increase in their current metal removal rates, while at the same time having a higher security in their machining processes. Safe-Lock also has a positive effect on tool wear."
"We have established Safe-Lock as a standard in roughing and heavy machining for which a variety of tools are available worldwide," said Andreas Haimer, president of the Haimer Group. "We are very proud and happy to have reached a strong partnership with OSG, one of the largest and leading producers of tools in the world."
