Omax Corp. presents a virtual trade show
June 19, 2020 - 04:45pm
Omax Corp.
KENT, Washington, June 9, 2020 – Omax Corp. has announced a virtual trade show to feature the ProtoMax abrasive waterjet. Using the ProtoMAX abrasive waterjet as a teaching tool for the next generation of manufacturers, OMAX will present a program of design, machinery, and innovation as it pertains to the advancements of abrasive waterjet technology.
During this virtual trade show, OMAX will be specifically looking at how the ProtoMAX perfectly fits into an academic setting. See the ease-of-use operation of the waterjet from software to cutting. Learn about curriculum guides for a seamless integration of the waterjet into your program. Experience the free software for any classroom size. Though the event will focus on academic applications, it will be open to all.
This event is fully online and will occur June 25th at 9 am PDT. Register for the event here: https://www.omax.com/virtual-trade-shows/experience-protomax
The ProtoMAX is an excellent user-friendly machine to build a curriculum around advanced manufacturing technology. Compact, safe, and easy-to-use, the ProtoMAX is a perfect teaching tool. Several universities have elected to add ProtoMAX to their engineering, material sciences, robotics, and arts programs, allowing students to experience hands-on innovative technology. With the clamshell cover and submerged cutting, the ProtoMAX is a safe and quiet (approx. 76 dB) iteration of a light industrial machine.
Featuring OMAX engineering in a space friendly package, the ProtoMAX delivers 30,000 psi cutting power with a 5 hp pump. Whether metal, glass, plastic, or wood, the ProtoMAX cuts virtually any material under 1 in. thick with a 12 in. by 12 in. cutting area. The system utilizes a 230-240 VAC, single phase outlet and does not require any hardwiring. The pump and cutting table are on casters for easy relocation. Work material is submerged under water for clean, quiet cutting that won’t disrupt a shared workspace. The ProtoMAX cuts with no heat-affected zone and no change to the material properties.
  • abrasive
    abrasive
  • abrasive waterjet ( AWJ)
    System that uses high-pressure waterjets in combination with a slurry of fine abrasive grains to machine materials. See waterjet cutting.
  • heat-affected zone
    heat-affected zone
    That portion of the base metal that was not melted during brazing, cutting or welding, but whose microstructure and mechanical properties were altered by the heat.
  • robotics
    robotics
04/15/2024
04/11/2024
