- metalworking
metalworking
- threading
threading
- turning
MSC Industrial Supply Co., the Melville, N.Y.-based distributor of metalworking and maintenance, repair and operations (MRO) solutions, has increased its selection of Kennametal cutting tools to 54,000 total items. MSC customers gain access to almost all of Kennametal's metalworking products, including milling, turning, holemaking, threading and tooling system products.
To streamline shopping, www.mscdirect.com features lists of specifications, dimensions and other details relative to each item, as well as a variety of search filters to help customers locate the appropriate tooling, and real-time pricing and inventory information so customers can see whether the item is in MSC's inventory or available to be shipped directly from Kennametal, which is based in Latrobe, Pa.
