MC Machinery releases Covid-19 impact infographic
August 10, 2020 - 01:15pm
Eight out of 10 manufacturing employees continued to work full-time on-site, according to an online survey conducted by MC Machinery Systems to measure the pandemic's impact on the industry. Results from the survey, which included 351 participants, are highlighted in the information graphic "The Impact of the Covid-19 Pandemic on the Manufacturing Industry" (seen below).
Headquartered in Elk Grove Village, Illinois, MC Machinery Systems is a manufacturer of laser, press brake, wire EDM, sinker EDM, milling, high-speed VMC, automation equipment and consumable products. A subsidiary of the Mitsubishi Corporation, MC Machinery serves industries including aerospace, mold and die, job shops, medical and energy.
MC Machinery Covid 19 InfoGraphic
  • gang cutting ( milling)
  • milling
  • wire EDM
    wire EDM
04/15/2024
04/11/2024
