Kyocera Has New Metalworking Tech at JIMTOF 2016
November 18, 2016 - 05:45am
 Kyocera Group is exhibiting a range of newly developed metalworking tools at the Japan trade show JIMTOF 2016. These will include the new CA3 Series CVD coated carbide indexable cutting tool inserts for cast iron machining; the Magic Drill DRA, a high-performance modular drill; and the MFH Micro, a tiny-caliber high-feed cutting tool, the company stated in a news release. Highlights include:
CA3 Series--New cutting tool materials for cast iron: The CA3 Series has achieved longer tool life and consistent processing of cast iron through a newly developed CVD coating with a pink-gold finish over a carbide base metal that improves the adhesion strength of the coating layers. Newly designed blade-edge shapes maximize performance even under high-load machining.
Magic Drill DRA,  is a modular drill that combines drilling accuracy with chip control. Its helix angle and flute design have been optimized to increase strength and prevent deflection. Drilling accuracy is achieved by reducing the cutting force through a special S-shaped chisel edge that minimizes thrust and vibration during drilling.
Click here to read more.
  • chemical vapor deposition ( CVD)
  • cutting force
    cutting force
  • cutting tool materials
    Cutting tool materials include cemented carbides, ceramics, cermets, polycrystalline diamond, polycrystalline cubic boron nitride, some grades of tool steels and high-speed steels. See HSS, high-speed steels; PCBN, polycrystalline cubic boron nitride; PCD, polycrystalline diamond.
  • helix angle
    helix angle
  • metalworking
    metalworking
Author
Former Senior Editor
734-606-9673
