Haimer USA celebrates new HQ
June 02, 2016 - 07:00pm
Haimer USA last month celebrated the grand opening of its new 25,000 sq. ft. North American headquarters in Villa Park, Ill., with a ribbon cutting ceremony, distinguished guest speakers, on-site machine demos and presentations.
Haimer USA celebrated it new headquarters with a grand opening held May 18-20.
The 3-day event showcased the company's motivation for such a large investment in the new headquarters, namely:
  • state-of-the-art training facilities and show room,
  • new audio and visual equipment with wireless capabilities,
  • spacious reception area, lounge and 25-ft bar with German beer on tap,
  • new 5-axis grinding machine,
  • Haimer Shrink and Balancing machines in every room, and
  • a new high speed 3-axis vertical machining center.
  • grinding
  • grinding machine
    grinding machine
  • machining center
    machining center
  • tap
    tap
