GF Machining Solutions will feature its new AgieCharmilles Cut F series wire EDM, which balances high precision with productivity, during Eastec from May 16 to 18 in West Springfield, Massachusetts. Visitors to the company’s booth 1728 will get a first glimpse of this next-generation Wire EDM technology ahead of its global market launch later this year.
The versatile CUT F 600 Series provides manufacturers with extreme production control and flexibility for ultraprecise machining and high surface finish capability. The series builds on decades of GF Machining Solutions wire EDM technology development – thermal stabilization, enhanced axis encoders, improved ball screw precision and machine designs that reduce the effects of leverage and vibration for tight-tolerance part production.
The CUT F 600 optimizes safe cutting processes thanks to the company’s Intelligent Spark Protection System (ISPS) Spark Track platform. Also available is the optional iWire adaptive software module to reduce wire consumption and RFID SMART wire spools that store wire characteristics traceability-related data.
Users easily program the machines with the advanced UNIQUA human/machine interface (HMI) that combines optimal functionality and ergonomics for every skill level on a 19-inch vertical screen. The UNIQUA HMI adapts to either sequential or object-oriented programming and is compatible with all major CAD/CAM programs.
Also during EASTEC, GF Machining Solutions will feature its Mikron MILL S 200 U, a vertical high-speed machining center with unrestricted 5-axis machining capability. The machine is designed for the highest precision and surface quality and is well suited for tool and moldmaking and other high-precision parts production such as watch-making and micromechanics, electrode production, medical implants and devices, and fluidics.
For superior vibration damping and machining stability, the Mikron MILL S 200 U is built on a polymer concrete base and incorporates a robust 50,000 rpm spindle along with a separate cooling circuit for all linear axes and the circular swivel unit.
Micromachining and small-part precision is achieved with the use of low tactile forces in the Z axis and precise laser optics for measurement of very small tool diameters ranging from 25 mm to 20 mm. Multiple tool storage configurations are available with 30, 60 or 150 tool positions and the Mikron MILL S 200 U accepts a full range of automation and tooling solutions from GF Machining Solutions to further increase productivity.
- machining center
machining center
- milling machine ( mill)
- wire EDM
wire EDM
