Calculating tooling can help manufacturers diversify
Choosing the right tools, and determining the right tool calculations, is vital to overcome diversification challenges and developing new revenue streams.
July 8, 2021
Sandvik's tooling can help customers diversify its revenue streams.There will be a “next normal” for manufacturers in the wake of COVID-19, according to a report published by McKinsey & Company. With losses of revenue in some sectors while others experience unexpected spikes in demand, the crisis is forcing manufacturers to diversify its production capabilities.
James Thorpe, product manager at Sandvik Coromant, a global leader in metal cutting, said that choosing the right tools, and determining the right tool calculations, is vital to overcome diversification challenges.
McKinsey & Company’s COVID-19: Briefing note report predicts manufacturers can expect “lasting shifts in customer markets” and that resilience will be needed if manufacturers are to “to navigate an economically and socially viable path.” In other words, they must diversify to survive.
Fortunately, today’s engineers are well-versed in mixed production. That said, diversifying production is not without it challenges.
A tool for all materials
Choosing the right tooling solution is essential for facilitating changes in production. This is particularly essential for engineers that work with tough materials like duplex stainless steels, Inconel or heat resistant super alloys (HRSAs), and companies that work with multi-materials.
Calculating tooling can help manufacturers diversify imageThese operations require optimised tools with calculated cutting data. Drilling tools are a prime example. Drill penetration rates can typically vary from 50 to 1000 mm/min. For these tools, precise calculations are vital for avoiding poor tool life or causing premature tool failures. If component material is changing, then drilling cutting data will have to change.
What does the term “the right” tool mean? With drills, this normally refers to tools that perform for longer and produce better quality holes, particularly in tough materials, like Inconel.
Thorpe said that Sandvik Coromant has developed a range of CoroDrill 860 solid carbide drills with optimised geometries suited for different applications that involve tough, difficult materials as well as malleable, abrasive and soft materials typically found in the ISO-K and ISO-N families. The range includes the CoroDrill 860-GM with enhanced -GM geometry, optimized for multi-materials and applications.
Other tools in the range, like the CD860-PM, are optimised for drilling ISO-P steels. The CD860-SM is optimised for ISO-S materials for aerospace parts manufacturing. The CD860-GM is particularly useful for general engineering with mixed-materials, where productivity is important and engineers seek to diversify their production, said Thorpe.
The CD860-GM’s polished flute design improves the evacuation of chips and yields greater hole quality. It is made from a fine-grained carbide substrate that increases hardness while maintaining toughness. In addition, the drill is tip-coated with a multi-layer physical vapor deposition (PVD) thin-film coating, which is key to improving the drill’s productivity and tool life.
This was put to the test by an automotive engineering company in South Korea. The company used the CD860-GM to machine a transmission connector in ISO-P material, then compared its performance with a competitor’s drill on the same component. The cutting data used was a cutting speed (Vc) of 100 m/min, a cutting feed (Fn) of 0.21 mm/rev and a drilling depth of 10 mm. In the end, the customer reported a 1,150% increase in tool life with the CD860-GM.
Going online
Productivity advantages, like those demonstrated in South Korea, can be crucial in helping manufacturers diversify their production while remaining competitive. But, just as important are the cutting data calculations that must be optimized for any given application. However, determining this for a new product may require expert opinion.
With the travel restrictions of COVID-19, a tool specialist might not be able to come and visit a facility. But, today’s engineers can calculate the best values, and marry these to the best-recommended drill for the job, by using online software.
To choose the right tool and cutting data for new or existing applications, Sandvik Coromant have developed the CoroPlus Tool Guide. The Tool Guide not only selects the correct tool, it provides cutting data and anticipated tool life for the specific application
Thorpe said that the ability to make such important decisions, in relation to tooling and its calculations, is vital if manufacturers are to diversify and do so effectively. What’s more, the ability to access this guidance online could be crucial for engineers adapting to the circumstances of COVID-19.
Combined with optimised tools like the CoroDrill 860 range, the challenges of what McKinsey & Company calls the “next normal” could also be a time of opportunity for manufacturers and engineers.
  • physical vapor deposition (PVD)
    Tool-coating process performed at low temperature (500° C), compared to chemical vapor deposition (1,000° C). Employs electric field to generate necessary heat for depositing coati…
  • stainless steels
  • cutting speed
Scroll for the next story
