BLM Group USA Corp. announces live machine, software demonstrations
May 15, 2020 - 03:15pm
BLM Group USA Corp.
Novi, Michigan. — BLM Group USA Corp. has announced that it is offering live, interactive machine and software demonstrations of its fabricating solutions for tube, pipe and more. Recognizing the increase in remote work and social distancing, BLM is offering these live broadcasts to enable customers and prospects to connect virtually and participate in demonstrations in real time.
Live demonstrations are available on the following topics:
• Tube Bending & End-Forming
• Lasertube Cutting
• Flat Sheet Laser Cutting
• 3D Laser Cutting
• Sawing & End-Machining
Anyone interested in evaluating BLM machines, automation or software, should contact  sales@blmgroupusa.com to learn more and to reserve a date and time.
  • flat ( screw flat)
    flat ( screw flat)
  • sawing
    sawing
GROB Systems Inc., a developer of manufacturing systems and machine tools, has announced it will be hosting a Medical Technology event, together with industry partners Open0 Mind Technologies, Seco,…
03/28/2024
Mazak has joined major cybersecurity research universities and enterprises throughout the country as a collaborative partner with the Cybersecurity Manufacturing Innovation Institute.
03/26/2024
A pilot project for AI-based quality inspection has been successfully launched in the production unit in Šumperk, Czechia. The company said that the project has opened the door to achieving even…
