Short pulses offer long-term gains
Author William Leventon
August 01, 2016 - 02:45pm
You might think laser pulse lengths measured in nanoseconds—that is, billionths of a second—are short. But they’re long compared to those of picosecond (a trillionth of a second) and femtosecond (a quadrillionth of a second) lasers, which are known as ultrashort-pulse lasers.
Once confined mainly to laboratories and medical facilities, USPLs have become increasingly popular machining options over the last decade, thanks to lower prices and more-rugged designs intended for industrial settings.
For machining applications, one of the main selling points of USPLs is that they shrink—and sometimes eliminate—the heat-affected zone. “The pulses are so short that heat doesn’t have time to be absorbed significantly, or at all, into either the material you’re cutting or adjacent structures,” explained Ramsey Cook, business development manager for the micro-processing group at Trumpf Inc., Farmington, Conn., a USPL manufacturer.
If a manufacturer cuts a thin line into steel with a USPL, Cook said, the laser vaporizes steel molecules, leaving little melt or debris along the cut.
Cut by a TruMicro picosecond laser from Trumpf, this “bicycle” is dwarfed by a 2€ coin. Image courtesy Trumpf.
The idea is to eliminate secondary operations. "If you’re cutting metal heart stents, for example, you would prefer not to do any post-process operations to clean them because that improves throughput," said Jimmie Bates, director of operations and business development for Altos Photonics Inc., a USPL seller in Bozeman, Mont. "So you make the cut with a femtosecond laser, and you’re good to go."
Another advantage of ultrashort laser pulses is they cut transparent materials. "If you use a long pulse in glass, the beam might go right through it because there’s no absorption," said Ronald Schaeffer, CEO of PhotoMachining Inc., Pelham, N.H., which uses USPLs for micromachining. "When you get down to very short pulses, you actually have absorption in some of these otherwise transparent materials."
USPLs are used to cut and drill thin parts made of almost any material. In the U.S., Bates noted, there’s growing demand for femtosecond lasers to drill automotive nozzles. The medical device market is “growing quite large” as well, he said, with femtosecond lasers being used to make products like heart stents, catheters and guide wires, as well as for consumer-electronic applications such as cutting hardened cellphone glass.
In addition to those markets, Trumpf’s picosecond lasers are widely applied in the aerospace industry to cut turbine blades and drill engine holes, Cook said. He also sees welding of disparate materials while minimizing heat as a possible "new direction" for USPLs.
As for USPL downsides, Schaeffer noted processing is relatively slow, "so you want to stay with thinner materials." Anything over 1mm is generally considered too thick for USPLs, he said.
Cost is also an issue. Although prices are decreasing, the devices can be anywhere from three to 10 times more expensive than longer-pulse lasers, Schaeffer said.
According to Bates, picosecond lasers range from $80,000 to $200,000, while femtosecond lasers run from about $100,000 to $300,000. These high upfront costs have prevented USPLs from moving into a wider range of applications.
In addition, cost of ownership is higher because it’s more difficult to keep USPLs running at their specified performance level over the long term than other types of lasers, Bates said. "We are making great strides in producing more-robust lasers, and there are now thousands of picosecond and femtosecond lasers in 24/7 production environments. But they’re a more-complex beast than a fiber laser, and, generally, that means they’re going to require more maintenance."
On the other hand, Cook said USPL owners benefit when it comes to cost per part. He pointed out that using a USPL to drill thousands of holes that require little post-processing is much more cost-effective than applying a cheaper drill but then spending a lot of time and money to remove plenty of burrs and debris and smooth rough edges.
What’s more, there’s good news about those hefty USPL price tags. Schaeffer said more laser manufacturers have entered the USPL market in the last couple of years—and the increased competition is driving down prices.
"Femto lasers are almost to the level of nanosecond lasers,” he said. “And at that point, why bother using a nanosecond laser?"
  • heat-affected zone
    heat-affected zone
    That portion of the base metal that was not melted during brazing, cutting or welding, but whose microstructure and mechanical properties were altered by the heat.
Author
Contributing Editor
William Leventon is a contributing editor to Cutting Tool Engineering magazine. Contact him by phone at 609-920-3335 or via email at wleventon@gmail.com.
