Modular fixturing pros and cons
Author Michael C. Anderson
October 19, 2017 - 02:15pm
Modular fixturing at its best offers the stability and accuracy of dedicated workholding with the flexibility to be reconfigured quickly for a variety of parts. The design and building of a dedicated fixture for a specific part or family of parts takes time and effort, whereas users can assemble modular fixtures quickly—particularly if they already have the needed fixturing components in their toolrooms.
Those components include subplates and tombstones with a standardized grid pattern for holding an interchangeable assembly of fixtures, vises and accessories, such as blank tooling plates, angle plates, parallels and workpiece-setup components (for example, locators, utility blocks and clamps). Adapter plates that can be used to convert third-party vises, rotary tables, chucks or other devices into modular accessories are also often needed.
Image courtesy of Bluco.
Modular fixturing components allow a job shop to more quickly respond to its customer’s need, said Aaron Hull, senior manufacturing engineer at Carr Lane Manufacturing Co., St. Louis. “You can put a fixture together in a day and start cutting.” This is a big advantage for core customers of modular systems, the growing number of job shops that typically see high-mix, low-volume production.
Modular Investment
A well-stocked modular-fixturing toolroom is a serious investment, which may be hard for a job shop to rationalize.
“Whether it’s a dedicated fixture or their first step into modular fixturing, it’s a big challenge for high-mix, low-volume shops to justify the cost of the fixturing when it’s for a job that isn’t going to produce a lot of parts,” Hull said. “Seeing the payback can be difficult if you’re looking at it from the standpoint of a single job.”
He said the beauty of modular fixturing is that a shop can buy the fixturing components, build a fixture for a particular part, disassemble it and reuse the components for a different part. “You can spread out that fixturing cost across several parts rather than [incurring the cost of] building a dedicated fixture for a single part and having that cost need to be absorbed by that single part number.”
Carr Lane Manufacturing’s fixture plate options include vises.  Image courtesy of Carr Lane Manufacturing.
But realizing that capital-investment mind-set isn’t always easy, Hull acknowledged. “It’s difficult for them to figure out how to spread the cost throughout all those different jobs because they don’t know what job is coming next week or next month. It can be a challenge to swallow that large up-front cost for a complete modular-fixturing system. What jobs do they tie that cost to, and how does that work in their accounting system?”
Carr Lane Manufacturing allows a wary job shop to stick its toe in the water of modular fixturing before choosing to dive in all the way, according to Hull. The company offers complete modular-fixturing kits—ones with varied components and sizes.
He said: “But we also sell all the components individually. Someone doesn’t have to start out buying a complete system. They can start small and grow the kind and number of components they have in their toolroom as they need them.”
The company has a thick catalog of options. “There are many different components available, in English and metric units,” Hull said. “We are a manufacturing facility, and we make most of the components right here in St. Louis.”
Cross-System Challenges
And that’s just one company’s catalog. The available modular-fixturing components and systems are many and varied, and, whatever the application, chances are that products exist that can help.
For a job shop, such variety is all good, isn’t it? As new jobs and new kinds of jobs come in, the shop can pick from a smorgasbord of fixturing options.
Example of a Stevens Engineering modular-fixturing kit. Image courtesy of Stevens Engineering.
But it’s not that simple, according to Gordon Coope, president of Stevens Engineering Inc., Phoenix, which has specialized in modular fixturing for more than 35 years. Problems arise when the best fixturing option for a new job won’t work with the modular components from earlier jobs—an occurrence more likely when more than one modular fixturing company is involved.
“Workholding has evolved into a multiplicity of seemingly incompatible products,” he said. “Companies that purchased a product can find themselves stuck.”
Examples he noted include:
  • A workholding company's sytem that uses 50mm (1.97") spacing with M12 threads under a 12mm (0.47") bushing. “Their vises mount on this spacing, and no other company makes off-the-shelf products to this spacing.”
  • Another company's system incorporates 2" (50.8mm) centers with 1/2-13 threads under a 1⁄2" (12.7mm) bushing.
  • Stevens Engineering itself uses 1.25" (31.75mm) grid spacing with alternating bushings and threads.
  •  Every model of a popular brand of vise has different hole spacing, “as though a different product team designed each vise.”
He noted that unlike machine spindles, which are available in just a limited number of choices—CAT 40, CAT 50, BT 30 and a handful of others—machine tables and pallets are not standardized. “T-slot size and spacing or tapped hole size and spacing can be different even within a single brand of machine,” Coope said.
One result is that a shop turns to subplates engineered to hold disparately sourced fixturing components—a good workaround, Coope acknowledged, but it tends to keep that shop locked into a single style of system.
“There’s a lot of loyalty to specific brands or systems. A shop thinks of itself as a ‘Kurt shop’ or a ‘Chick shop,’ or a ‘Stevens Engineering shop.’ And none of these systems are made to work easily with the others,” Coope said.
For this reason, at Stevens Engineering “we get lots of calls from manufacturers that ask, ‘Do you have anything that will work with this other style of workholding?’”
And not only from job shops. He noted a major shoe manufacturer in Oregon for whom Stevens made all its fixtures when it tooled up production of new molds for the soles of shoes. And for the past 15 years, a Connecticut-based aerospace manufacturer has relied on Stevens to produce fixture plates for its coordinate measuring machines used to inspect parts. Both companies needed Stevens Engineering parts designed to accommodate different legacy systems.
Coope said Stevens Engineering has often worked with other modular-workholding companies to help customers overcome specificincompatibility issues. “When we talk to fellow modular-fixturing companies, they acknowledge that it’s an issue for customers.” It’s an issue that prospective modular-fixturing users need to think about before they buy. (See sidebar)
From Components to Systems
Other modular-fixturing companies acknowledge the challenge that incompatible components hold for their customers. Carr Lane Manufacturing’s Aaron Hull said his company also works to bridge the gaps.
“For example, we have systems that have a ball-lock-style receiver plate that would go on the table or a horizontal tombstone and then a subplate that can be put on that Carr Lock fixture receiver plate,” he said. “You can set up your [otherwise incompatible] modular fixture on the Carr Lock subplate while the machine is running the previous job. From there you could immediately go from your modular-fixturing subplate to another subplate such as a blank Carr Lock subplate to which you’ve attached a vise.”
Brian Dodsworth, director of sales at Bluco Corp., Aurora, Ill., emphasized that a job shop that acquires its modular-fixturing components in a job-by-job, piecemeal fashion is headed for unnecessary complications. The best solution, when possible, is for the shop to think of modular workholding not as a collection of components but as a complete system—and that a good time to acquire one is when a machining center is purchased.
Bluco modular-fixturing setup on a horizontal machining center. Image courtesy of Bluco.
This leads back to the challenge of finding a cost justification that is more like a capital investment than the cost of a single job—a challenge made greater after just making a large capital investment in a machining center.
But if it can be done, it helps avoid more costly issues down the road. In short, Dods-worth said, if a shop starts with a genuinely comprehensive system, it won’t have compatibility issues.
“When you design your machining center from the ground up so that you have removable plates, you can swap a Bluco tooling plate off and put in a plate with, say, a Kurt vise when that makes sense. You’re not locked in,” he said.
For example, Bluco’s manufacturing facility in Aurora uses Kurt vises, as well as Ball Locks from Jergens Inc., Cleveland. “So if I were talking to shops who had that concern, I would step back and paint a bigger picture of how to approach the tooling for their machine so they can have interchangeability.”
Dodsworth said Bluco’s tooling system “hasn’t really changed in 20-plus years.” The company has innovated and adapted over time—“it hasn’t just been static. But the core system hasn’t changed. And when you have a comprehensive system, you don’t ‘grow out of it’” and need to use other vendors’ fixturing.
Closed-Door Policy
There’s another mind-set found at some customers that Dodsworth is trying to change. “The common method of workholding setup is that the machine stops, you open the doors, you tear down your fixture and set up your next fixture—all done in the machine, with the doors open and the machine idle,” he said. That might be OK for long production runs, but for low-volume, high-mix shops, it’s a throughput killer.
When the doors are open because the machinist is setting up fixtures, the spindle is idle, hurting productivity. “When those doors are open, you’re not making chips, [and therefore] you’re not making money,” Dodsworth said.
Better to set up offline. “With our system, the fixturing is all on a tooling plate, so all you have to do when you open doors is swap out tooling plates,” he said. “Your next fixture has already been set up on a tooling plate out- side the machine, offline, while the spindle was still spinning on the previous job.” So when the door opens, the machinist disconnects the tooling plate from the machine, pulls it out, loads the next one, closes the door and hits the button, and the machine is running again. “You’re really keeping to a bare minimum the amount of time those doors are open and [the machine is] not producing.”
Carr Lane Manufacturing, Stevens Engineering and other companies also promote the benefits of offline-fixturing setup to their customers as a boon to throughput. Some suggest it, but at Bluco, it comes across as more than that. As Dodsworth sees it, there have been two great innovations that made workholding setup easier: the use of CAD modeling to speed up fixture design and modular workholding to speed up fixture building.
“We think that offline fixture setup needs to be the third item on that list,” he said. “It’s an innovation that should become a standard practice for improving throughput.”
Getting Started With Modular Fixturing
Because of the ongoing issue of incompatible modular-fixturing systems, Stevens Engineering President Gordon Coope has advice for shops looking at any modular-fixturing product or product line—including his own:
  • Think through the ramifications of embracing a product line. “Make sure that the supplier has broad enough offerings and accuracy specs to match your requirements.”
  • Plan for the future migration of fixturing. “Often, fixturing that has been running on vertical machines is moved to horizontals, but the person in charge of the horizontal
  • fixturing is not necessarily the person fixturing verticals.”
  • Plan for adapter plates that are made for the purpose of adapting across product lines.
  • Try to maintain an organized CAD library of your fixturing “to help your programming staff and toolroom.”
  • Finally, when necessary, be ready to develop ways of integrating the best offerings of multiple companies.
Stevens Engineering has been trying to address all these issues, he said. “Most likely, other companies are also trying.”                                               —M. Anderson
  • bushing
    bushing
    Cylindrical sleeve, typically made from high-grade tool steel, inserted into a jig fixture to guide cutting tools. There are three main types: renewable, used in liners that in turn are installed in the jig; press-fit, installed directly in the jig for short production runs; and liner (or master), installed permanently in a jig to receive renewable bushing.
  • centers
    centers
  • family of parts
    family of parts
    Parts grouped by shape and size for efficient manufacturing.
  • fixture
    fixture
  • machining center
    machining center
  • modular fixturing
    modular fixturing
    System in which fixtures are constructed from standardized, reusable components. Fixtures are assembled and disassembled quickly. Basic styles are subplate, dowel-pin and T-slot. See fixture; modular tooling.
Author
Former Senior Editor
734-606-9673
Contributors
Bluco Corp.
(800) 535-0135
www.bluco.com
(314) 647-6200
www.carrlane.com
(602) 272-6766
www.stevenseng.com
