Crash avoidance without simulation
Author Brandt Taylor
March 17, 2020 - 11:45am
The introduction of CNC machine tools changed the machine shop world. Productivity is way up, and shops can produce parts and part features that were out of the question in the past. But unlike most machine operators, if you tell a CNC machine to kill itself, it will. So in programming language, G0Z-0.500 is good for a move, but G0Z-5.00 can break something. To paraphrase Benjamin Franklin, breakage prevented is money earned, so let’s use low-cost methods to raise the bottom line.
Here, I’ll discuss how to prevent crashes on a three-axis CNC milling machine. This could be a Bridgeport-type machine, a lathe, a bed mill or a machining center.
The first step in solving a problem is to define it. A crash is when a cutting tool contacts a solid object while a machine does a rapid move (G0 in G code). For the three-axis milling machine we’re using, the G code is generated with or without the aid of a CAM program, and there is no simulation software available to debug the code.
Good shop practices deliver code that will run safely and produce correct parts. The procedure involves using a machine tool to verify the part program. This starts with programming. A shop should have a standard procedure for determining the z-axis zero position with regard to the workpiece and a standard positive z dimension for a clearance plane.
Rapid (G0) moves in the x, y plane should be done at the clearance plane or above it. When clamping a part with a vise, set the z zero at or above the vise jaws. Confusion can lead to trouble, and having standard procedures reduces confusion. If a workholder protrudes above the z zero, it needs to be documented for the machine operator. Double-check absolute (G90) and incremental (G91) position commands, as well as the z positions.
A copy of the part print is made that defines the x, y and z zero locations, the block number of rapid moves and the x, y position of the downward rapid z moves. Give this information to the operator.
The machine then is set up for the job, and the program is loaded. The tool length offset is set short so the cutting tool will not touch anything. Alternately, a toolholder with no cutting tool can be used. On a machine with an automatic toolchanger, one tool position can contain a toolholder with no cutting tool to be used for debugging.
The feed rate is set well below the speed of the rapid moves. This setting makes it obvious to the operator whether the machine control is in rapid or feed. These are modal commands that stay in effect until superseded. Say the machine is in rapid in block N100 and is supposed to go into feed rate in block N101, but G1 is not programmed in block N101. As a result, the tool will rapid into the workpiece. The operator needs to catch this.
The program is run one block at a time.
At rapid moves, the operator observes the z positions and documents any problems with the block number and the x, y position.
Rapid moves inside a workpiece cavity require special care.
While debugging, the operator can check geometry. For example, if the program drills a bunch of holes, it’s easy to see if they are in the right locations.
  • automatic toolchanger
  • clearance
    clearance
  • feed
  • gang cutting ( milling)
  • lathe
    lathe
  • machining center
    machining center
  • milling
  • milling machine ( mill)
  • milling machine ( mill)2
  • toolchanger
    toolchanger
  • toolholder
    toolholder
Author
978-838-2979
Brandt Taylor is owner of Berlin, Massachusetts-based Taylor Engineering, a machine shop and manufacturer of lathe chuck jaws. He can be reached at gbrandttaylor@gmail.com. For more information about the chuck jaws, visit www.stopjaws.com.
