Combating Tool Decay
Author K.V. Rangaswamy
March 01, 2009 - 11:00am
A parts manufacturer finds that brushing the cutting edges of tools with nylon bristles extends tool life, improves part quality and reduces manufacturing costs.
As parts manufacturers continue to boost productivity, customers typically demand a reduction in the price of machined parts every year, feeling they deserve a “productivity discount.” However, profitability is dangerously eroded. To survive and hopefully thrive, a manufacturer’s input costs must be reduced.
Some areas for improvement include employee productivity gains, longer tool life, better management of consumables and a reduction in energy consumption. A team at ABI Showatech (India) conducted work in those four areas and found tool life improvement provided significant advantages.
Courtesy of ABI Showatech
Tool life and the quality of the threaded aluminum component improved after ABI Showatech started brushing the tap’s cutting edges.
An initial breakthrough came when tapping was studied for thread quality. This was prompted by a customer complaint about fine metal particles sticking to thread walls.
We tried various methods, such as increasing the coolant pressure from 3 to 10 bar (44 to 145 psi) when tapping, applying taps with wear-resistant coatings and enhancing lubricating properties. Unfortunately, the improvements were minimal and not satisfactory.
Examining a tap’s cutting edges under magnification revealed minute particles adhering to the edges. We concluded that these metal particles were from the aluminum workpiece material and created a barrier. Although minute, this barrier prevented the tap from effectively cutting the threads. Our assumption that increased coolant pressure would remove the metal particles proved incorrect.
Then the idea of cleaning taps with a brush—a mechanical operation—was proposed, which has to be done for every tapping cycle. To prevent the time-consuming interruption of the tapping cycle for brushing in a machining center, a brush with nylon bristles was mounted to the fixture, and the machine was programmed to swipe a tap against the stationary brush before commencement of the tapping cycle.
As a result, the machine operator reported improved quality of the threaded component after gaging it. The threads were clean and free of loose, tiny burrs. The thread quality was maintained even after exceeding the prescribed tool life, which we determine for every tool applied to help manage tool inventory. New tool life parameters for the taps were then established (Table 1).
Table 1: Tap life before and after brushing.
No. Tool no. Brushing introduction date Tool life to date Tool life before brushing
1
M10 tap
Oct. 25, 2004
n 13,242 tap 1 life
n 11,894 tap 2 currently running
6,000 holes/tool
Before and after brushing was introduced, the M10 X 1-6H tap from Emuge (India) was run at a 600-rpm spindle speed and a 1-mm/rev. feed. The tool cost savings from brushing was about $650 per year.
Brushing began with taps and was extended across the board for all cutting tools. The extension of tool life was not uniform for every tool, but the results were encouraging. Tool life improved from 200 to 400 percent by brushing the cutting edges at the beginning or end of each machining cycle. Tests were conducted for more than 6 months on ceramic indexable milling inserts.
Table 2: Tool life comparison of drills applied for machining aluminum master cylinders before and after brushing.
Equipment Tool name Tool material Tool no. Tool life (holes/tool) Tool life increase
        Before brushing After brushing
1. VMC
Drill
Carbide
11DF5238
8,000
20,000
2.5×
2. VMC
Drill
Carbide
11DV5237
700
1,500
2.1×
3. VMC
Drill
Carbide
704473
8,000
20,000
2.5×
4. VMC
Drill
Carbide
11DF5227
7,000
20,000
2.9×
5. VMC
Form drill
PCD
11DF5274
20,000
55,000
2.8×
6. VMC
T/FIX drill
Carbide
11DF5224
8,000
12,000
1.5×
The advantages of tool brushing includes improved part quality, longer tool life, lower tool inventory and an increase in machine uptime because of a reduction in the frequency of tool changes. The total cost savings for brushing all tools in our operation is about $12,600 per year.
We tried to extend tool life further by using brushes impregnated with abrasives, such as aluminum oxide or silicon carbide. However, tool life was reduced by using abrasive-impregnated brushes in all cases.
Work is being performed to fix a rotary ring brush in a tool’s home position in an automatic toolchanger, which should improve cycle time. CTE
About the Author: K.V. Rangaswamy is executive director for ABI Showatech (India) Ltd., a high-volume manufacturer of automotive parts, including master cylinders, turbochargers and camshafts. He can be reached via e-mail at rangakv1933@yahoo.co.in or balaji.r@turboenergy.co.in.
  • aluminum oxide
    aluminum oxide
    Aluminum oxide, also known as corundum, is used in grinding wheels. The chemical formula is Al2O3. Aluminum oxide is the base for ceramics, which are used in cutting tools for high-speed machining with light chip removal. Aluminum oxide is widely used as coating material applied to carbide substrates by chemical vapor deposition. Coated carbide inserts with Al2O3 layers withstand high cutting speeds, as well as abrasive and crater wear.
  • automatic toolchanger
  • brushing
    brushing
    Generic term for a curve whose shape is controlled by a combination of its control points and knots (parameter values). The placement of the control points is controlled by an application-specific combination of order, tangency constraints and curvature requirements. See NURBS, nonuniform rational B-splines.
  • coolant
  • feed
  • fixture
    fixture
  • gang cutting ( milling)
  • machining center
    machining center
  • milling
  • tap
    tap
  • tapping
    tapping
  • toolchanger
    toolchanger
Author
Executive Director
