Port Mills vs Port Tools: The Chatter Showdown! | Scientific Cutting Tools
Are port mills the solution to chatter? Watch them go head-to-head against traditional port tools. π οΈ Get our tools here! π Today we are here testing our brand new port mills. We're going to grind it up against four different sizes of SAE ports with our pilotless port tool.
Today we are here testing our brand new port mills. We're going to grind it up against four different sizes of SAE ports with our pilotless port tool. We're going to do dash size 12, 16, 20, and 24. We've got some 304 stainless that we've already drilled and milled out to be the right diameter. We're going with a shorter, non-traditional length on this because we've been seeing that more and more. What we've been running into a lot is on these ports that you can't use a reamer-style port tool for. We're having a lot of trouble with chatter, so we're going to see if our port mill can help solve some of that problem today.
ββββββββββ
Connect with Scientific Cutting Tools!
π Website π https://sct-usa.com/
π₯ Youtube π https://www.youtube.com/user/SCTCuttingTools/feed
π· Instagram π https://www.instagram.com/scientificcuttingtools/
π¦ Facebook π https://www.facebook.com/scientificcuttingtools
ββββββββββ
About Us:
When Scientific Cutting Tools was founded over sixty years ago, no one could have imagined what the world of industrial manufacturing would look like today. While many things have changed over the last six decades, one thing has remained the same: our commitment to provide our customers with the highest quality cutting experience. We offer seven standard product groups and over 8,000 SKUs, all of which are produced right here in the USA.
In addition to standard, ready-to-ship products, our dedicated team of engineers offer individualized custom and modified options that are tailored to your exact specifications. Our commitment doesnβt end with delivery: we provide ongoing support to address any questions or concerns.
ββββββββββ
00:00 Why are port tools causing so much chatter?
02:02 Why is changing port tools so time-consuming?
02:57 Can a port mill eliminate chatter?
03:50 How do port mills work differently than port tools?
05:16 Which tool produced the better finish?
06:00 How did the Versa coating perform in stainless steel?
06:36 How can you reduce chatter with your current port tools?
07:24 When should you use a port mill instead of a reamer-style port tool
#PortMills #PortTools #ScientificCuttingTools
