Boosting Threading Efficiency: Five Tips to Avoid Tap Breakage
Published Date
April 24, 2024 - 12:00:pm
Didn't get your question answered? Click here to ask a question, and receive a free drill size pocket card!
Join us for an Ask CTE Contributors webinar led by industry veteran Tom Kowalski, Regional Manager for EMUGE-FRANKEN USA, when he provides invaluable insights on "Avoiding Tap Breakage with These Five Tips". Designed for manufacturers spanning all industries, this webinar will delve into the intricacies of tap selection, drilling considerations, and crucial decision-making that EMUGE-FRANKEN uses for optimizing thread quality and tool life – and avoiding the dreaded broken tap!
In this educational session, Tom will cover:
  • The five critical questions that every engineer and machinist must address before selecting a tap, providing a roadmap to efficiently navigate the maze of options.
  • Understanding the impact of tool holders on thread quality, tool longevity and mastering the art of selecting the correct lubricant tailored to your specific application requirements.
  • When to "Tap Out" and consider the shift towards thread milling, offering invaluable guidance on making this strategic transition, seamlessly.
Drawing upon his 24 years of technical expertise with EMUGE-FRANKEN, Tom will provide practical tips and actionable strategies to empower engineers in mitigating tap breakage risks and elevating machining efficiency.
Don't miss this opportunity to arm yourself with the knowledge and tools needed to transform your tapping and threading operations. Register now to secure your spot.
Download Ask CTE Contributors Slideshow (PDF)
Download EMUGE slideshow (PDF)
Download the Multi Program Brochure
Download the SoftSynchro® High Performance Tap Holders Brochure
Email : Technical@emuge.com
Phone: 800-323-3013
Website: www.emuge.com
  • gang cutting ( milling)
  • milling
  • tap
    tap
  • tapping
    tapping
  • threading
    threading
MEDIA
06/26/2024
04/24/2024
04/04/2024
Cutting Tool Engineering is happy to announce the launch of Bourbon With The Editor, a new video…
