Swiss ID Burnishing Tools
September 23,2016
Swiss ID burnishing tools by Elliott Tool Technologies are ideal for accurate sizing, low microfinishing and surface hardening of ID holes down to 4 mm. With the tool body completely inside the tool block, the new 5918 series features an adjustment knob which protrudes from the rear of the tool shank, thus allowing the burnishing tool size to be adjusted for diameter without removal from the tool block. This cost-effective, easy-to-use tooling from Monaghan Tooling Group improves surface irregularities and tool marks, producing optimum surface finishes of 4-8 Ra in a single pass. This proven technique can eliminate secondary processes such as grinding, honing and polishing by automating those processes in the primary CNC machine. Doing so saves setup and processing time and labor costs and also enhances machinery utilization and shop floor productivity.
Compact burnishing tools are ideal for applications where the machine working envelope is limited, as is found in most Swiss-type turning centers, small CNC turning centers and when burnishing parts in subspindles where the machine working envelope is reduced.
Burnishing is an ideal way to accurately hold diameter tolerances in “tenths” (0.0001”) and produce microfinishes in the range of 2 to 8 Ra in most steels, stainless steel, aluminum and other ductile metals that have a hardness of under 45 HRC.  The new line of compact ID burnishing tools can be applied to a range of industries, such as medical, fuel systems, fluid power and small automotive components.
Economical, long-lasting and replaceable wear parts reduce the total cost over the life of the tool. Wear parts are easy to replace, with common tooling available from stock. Their operation and maintenance requires minimal training.
  • burnishing
    burnishing
    Finishing method by means of compressing or cold-working the workpiece surface with carbide rollers called burnishing rolls or burnishers.
  • centers
    centers
  • grinding
  • hardening
    hardening
    Process of increasing the surface hardness of a part. It is accomplished by heating a piece of steel to a temperature within or above its critical range and then cooling (or quenching) it rapidly. In any heat-treatment operation, the rate of heating is important. Heat flows from the exterior to the interior of steel at a definite rate. If the steel is heated too quickly, the outside becomes hotter than the inside and the desired uniform structure cannot be obtained. If a piece is irregular in shape, a slow heating rate is essential to prevent warping and cracking. The heavier the section, the longer the heating time must be to achieve uniform results. Even after the correct temperature has been reached, the piece should be held at the temperature for a sufficient period of time to permit its thickest section to attain a uniform temperature. See workhardening.
  • hardness
    hardness
  • inner diameter ( ID)
  • polishing
    polishing
  • shank
    shank
  • turning
