REGO-FIX's reCool coolant-through system is a quick, cost-effective, low-maintenance way to add the benefits of internal cooling to the live tooling used in CNC turning operations. reCool converts an existing tooling system to include through coolant in as little as 2 minutes.
The system sends coolant to the cutting edge much more effectively than spray pipes or nozzles. reCool applies to spindle speeds up to 12,000 rpm and delivers coolant pressure up to 1,000 psi (higher speeds and coolant pressures are optional).
Manufacturers who add reCool to their CNC turning operations remove heat from the cutting zone while they achieve better surface finishes, longer tool life, improved chip control and increased overall productivity. Furthermore, reCool's simple structure and special lubricated bearings make it an affordable, low-maintenance internal cooling system that provides ideal cooling of the cutting edge with either emulsion or oil and without scattering or spray losses.
The reCool system also works in conjunction with REGO-FIX collets, sealing and coolant flush disks, milling cutters and drills from 1.0" to 1.2" in diameter.
- coolant
- emulsion
emulsion
Suspension of one liquid in another, such as oil in water.
- turning
