Models FC-200D and FC-500D
Rush Machinery
Address
4761 Route 364
Rushville
14544
NY
United States
Phone
585-554-3070
Toll Free Phone
800-929-3070
Fax
585-554-4077
42.795892, -77.2597421
June 01,2011
Rush offers the Model FC-200D and Model FC-500D Polycrystalline Tool Grinders which allow for economical manufacturing and regrinding of: PCD, CVD, PCBN, Carbide, and HSS tools. These machines grind angles and radii on standard and special turning and milling inserts, boring tools, milling cutters, grooving tools, reamers, and other special tools. The rigid construction with a 3-HP variable speed grinding spindle provides for vibration-free grinding and fast stock removal.
Both the Model FC-200D and the Model FC-500D feature a unique video optical system with 15-120x (zoom) magnification and a black and white video monitor. This system provides a higher magnification and/or a larger field of view than most machine-mounted optical comparator systems. In addition, the video camera moves with the worktable for easy set-up and for inspection during and after grinding.
The Model FC-500D is a larger, more versatile machine than the FC-200D. In addition to all of the capabilities of the Model FC-200D, the Model FC-500D features vertical grinding spindle travel, a wheel travel range of 500mm and an oscillation stroke of 70mm. The Model FC-500D is also designed for grinding reamers, drills, end mills, and multi-step form tools.
  • boring
    boring
  • chemical vapor deposition ( CVD)
  • gang cutting ( milling)
  • grinding
  • grooving
    grooving
  • high-speed steels ( HSS)
  • milling
  • polycrystalline cubic boron nitride ( PCBN)
    Cutting tool material consisting of polycrystalline cubic boron nitride with a metallic or ceramic binder. PCBN is available either as a tip brazed to a carbide insert carrier or as a solid insert. Primarily used for cutting hardened ferrous alloys.
  • turning
