Model FC-250W
Rush Machinery
Address
4761 Route 364
Rushville
14544
NY
United States
Phone
585-554-3070
Toll Free Phone
800-929-3070
Fax
585-554-4077
42.795892, -77.2597421
March 01,2011
Rush Machinery offers the Model FC-250W Diamond and CBN Wheel Truing and Dressing Machine. The Model FC-250W is designed for truing and dressing of flats, angles, and radii on diamond and CBN single wheels and multiple wheel packs.
Use of the Model FC-250W allows for increased efficiency and accuracy by profiling, modifying profiles and truing wheels properly — offline of the production grinding machinery. The machine is simple to operate, quick, accurate and cost effective. The heavy duty one piece cast iron base provides extra rigidity and minimizes vibration.
Standard features include ExVision, a computer-driven vision system with a software program specifically designed for the FC-250W and its various applications; an automatic power zoom; and a 2-axis DRO for measurement.
  • cubic boron nitride ( CBN)
  • dressing
    dressing
  • grinding
  • profiling
    profiling
  • truing
    truing
    Using a diamond or other dressing tool to ensure that a grinding wheel is round and concentric and will not vibrate at required speeds. Weights also are used to balance the wheel. Also performed to impart a contour to the wheel’s face. See dressing.
  • vision system
    vision system
