Fluid Filtration
Rush Machinery
Address
4761 Route 364
Rushville
14544
NY
United States
Phone
585-554-3070
Toll Free Phone
800-929-3070
Fax
585-554-4077
42.795892, -77.2597421
September 01,2010
Ideal for the grinding, honing and lapping industries, Rush Machinery Inc.'s Grinding Fluid Filtration System is a high performance filtration system that utilizes edge filtration technology. Balanced clean and dirty fluid tank sizes ensure separation of clean and dirty fluids, even during the automatic regeneration cycle. This system can filter either oil or water, resulting in a high degree of filtration (oneµm for oils and fiveµm for water-based fluids) with minimal customer maintenance. For use with carbide, HSS, stainless steel and other materials, the Rush system allows reclamation of high value materials. Single and multiple pump configurations are available for clean fluid delivery and make the system highly flexible to meet customers' requirements. For dirty fluid handling, the system uses seal-less cast iron filter pumps that extend pump life.
  • grinding
  • high-speed steels ( HSS)
  • lapping
    lapping
    Finishing operation in which a loose, fine-grain abrasive in a liquid medium abrades material. Extremely accurate process that corrects minor shape imperfections, refines surface finishes and produces a close fit between mating surfaces.
