Ideal for the grinding, honing and lapping industries, the Rush FC300 Grinding Fluid Filtration System is a high-performance filtration system that utilizes edge filtration technology. Balanced clean and dirty fluid tank sizes ensure separation of clean and dirty fluids, even during the automatic element regeneration cycle. Unlike other systems, this system can filter either oil or water, resulting ina high degree of filtration (oneµm for oils and fiveµm for water-based fluids) with minimal customer maintenance. For use with carbide, HSS, stainless steel, ceramics, and other materials, the Rush system allows reclamation of high value materials.
Single and multiple pump configurations are available for clean fluid delivery and make the system highly flexible to meet customers' requirements. For dirty fluid handling, the system uses seal-less cast iron filter pumps that extend pump life.
Rush Machinery offers customized systems designed for specific machines and shop floor layout. Single and multiple machine and centralized configurations are available. All pneumatic and electrical controls are housed in conveniently located enclosures. Grinding Fluid Filtration System options include pre-filters for removing steel swarf when filtering steel or a mix of carbide and steel, as well as a selection of large capacity cooling systems made specifically for oil or water.
- ceramics
ceramics
- grinding
- high-speed steels ( HSS)
- lapping
lapping
Finishing operation in which a loose, fine-grain abrasive in a liquid medium abrades material. Extremely accurate process that corrects minor shape imperfections, refines surface finishes and produces a close fit between mating surfaces.
- swarf
swarf
