Rush Machinery Inc.'s Easy-Cut semiautomatic cutoff machine is for cutting carbide and HSS rod and tool ends from 1⁄8" to 1¼" (3mm to 32mm) in diameter. The fully-enclosed machine features a PLC, fl ood coolant, airactuated workpiece clamping, workpiece stop with LCD readout, automatic shutoff and a hydraulic feed cutting stroke with a neutral button for manual positioning and feeding.
- coolant
- cutoff
cutoff
Step that prepares a slug, blank or other workpiece for machining or other processing by separating it from the original stock. Performed on lathes, chucking machines, automatic screw machines and other turning machines. Also performed on milling machines, machining centers with slitting saws and sawing machines with cold (circular) saws, hacksaws, bandsaws or abrasive cutoff saws. See saw, sawing machine; turning.
- feed
- high-speed steels ( HSS)
