CNC automation for high-mix manufacturing
VersaBuilt's CNC automation line includes a range of standardized robotic automation systems designed specifically for machine shops that need flexibility, fast deployment, and measurable productivity gains. The company’s product lineup includes the MultiGrip Mill Automation System, DuoGrip Lathe Automation System, and ZPS Vise/Pallet Loading System.
June 25, 2026
CNC automation for high-mix manufacturing image
VersaBuilt’s CNC automation line includes a range of standardized robotic automation systems designed specifically for machine shops that need flexibility, fast deployment, and measurable productivity gains.
The company’s product lineup includes the MultiGrip Mill Automation System, DuoGrip Lathe Automation System, and ZPS Vise/Pallet Loading System. Together, these solutions support a wide range of part sizes, geometries, and production requirements commonly found in high-mix, low-volume manufacturing environments, the company says.
VersaBuilt’s automation solutions enable manufacturers to automate CNC mills and lathes without the complexity traditionally associated with robotic automation. The company’s systems utilize a common hardware and software platform across multiple machine types, allowing shops to deploy automation faster, train operators more easily, and expand automation initiatives with confidence.
VersaBuilt offers a no-programming-required approach. Operators can quickly teach new parts, adjust workflows, and begin production without relying on robot programmers or outside integrators. Most installations can be completed in a single day, dramatically reducing implementation costs and downtime.
The systems are designed to integrate with collaborative robotic platforms and are built to help manufacturers increase spindle utilization, reduce labor constraints, shorten setup times, and improve overall throughput.
For more information on its automation solutions, visit VersaBuilt.
