Auto-Cut CNC Carbide Rod Cutoff Machine
Rush Machinery
Address
4761 Route 364
Rushville
14544
NY
United States
Phone
585-554-3070
Toll Free Phone
800-929-3070
Fax
585-554-4077
42.795892, -77.2597421
April 01,2016
Rush Machinery offers “Auto-Cut,” a CNC carbide rod cutoff machine for the carbide tool and carbide rod manufacturing industries. The machine can double the production rate for cutting carbide and hardened steel rod when compared with manual cutoff machines.
It has an easy-to-use CNC with a touch screen operator interface.  Parameters can be quickly set for rod diameter and length. The machine automatically loads and cuts rods from a large-capacity magazine. Capacity of the “Auto-Cut” is 0.055” (1.4mm) to 1-9/16” (40mm) diameter carbide rod, up to 16” long, and it comes standard with a flood coolant system.
  • coolant
  • cutoff
    cutoff
    Step that prepares a slug, blank or other workpiece for machining or other processing by separating it from the original stock. Performed on lathes, chucking machines, automatic screw machines and other turning machines. Also performed on milling machines, machining centers with slitting saws and sawing machines with cold (circular) saws, hacksaws, bandsaws or abrasive cutoff saws. See saw, sawing machine; turning.
