Rush Machinery Inc. offers a production-rated Carbide Rod Cut-Off machine for carbide tool manufacturers and carbide rod processors. The "Auto-Cut," a CNC Carbide Rod Cut-Off Machine, can double the production rate for cutting carbide and hardened steel rod when compared with manual cut-off machines, according to the company. It has easy to use CNC controls with a touch screen operator interface. Parameters can be quickly set for rod diameter and length. An optical edge detection system monitors and compensates for wheel wear.
The machine automatically loads and cuts rods into precision lengths from a large capacity magazine. Capacity of the "Auto-Cut" is .055" (1.4mm) to 1-9/16" (40mm) diameter rod, up to 16" long, and the fully enclosed unit comes standard with a flood coolant system.
- coolant
