MSC expands Accupro line
December 15, 2013 - 06:00pm
MSC Industrial Supply Co., Melville, N.Y. expanded its Accupro line of metalworking products with the launch of new milling, threading and toolholding solutions.
MSC has added more than 650 milling items, including variable index tools with offset flutes, an increased selection of Nacro-coated progressive helix tools, new "blue coated" tools for materials between 55 and 65 HRC and a wider range of uncoated tools for machining aluminum. The company has also introduced a new general-purpose Accupro multi-tap solution. Additionally, MSC customers can choose from a wider scope of toolholder and drill chuck sizes.
According to Ryan Esposito, vice president of product management at MSC, the Accupro portfolio now includes more than 14,000 products. The line encompasses endmills; boring, grooving and threading tools; drills; taps; and toolholders.
"Accupro tools bring reliability, durability and affordability to virtually all metalworking applications, and MSC is constantly updating the line," he said. "We also provide Accupro customers with tech support and access to a range of inventory management solutions."-
MSC offers same-day shipping and a satisfaction guarantee on its Accupro products, according to the company. Customers can view and purchase Accupro products directly from mscdirect.com.
  • boring
    boring
  • chuck
    chuck
  • flutes
    flutes
  • gang cutting ( milling)
  • grooving
    grooving
  • metalworking
    metalworking
  • milling
  • threading
    threading
  • toolholder
    toolholder
Mazak has joined major cybersecurity research universities and enterprises throughout the country as a collaborative partner with the Cybersecurity Manufacturing Innovation Institute.
03/26/2024
A pilot project for AI-based quality inspection has been successfully launched in the production unit in Šumperk, Czechia. The company said that the project has opened the door to achieving even…
03/22/2024
Hypertherm Associates to award Powermax systems to 12 North American schools as part of Spark Something Great grant program.
