Establishing an effective machine tool and spindle service program
January 17, 2018 - 05:00pm
This article is courtesy of Gilman Precision.
If a spindle breaks down, what is your company’s plan of action? Is it the most practical and efficient way to deal with a down spindle? Spindles need maintenance at varying intervals based on the length and design of their operation. Normal use of any machine will cause wear and tear, the spindle being the component that receives the majority of the wear. It is necessary for spindles to run at the right speeds and feeds to minimize wear. Because of this, a good spindle program should consider the specific operational information of each individual spindle.
Companies need to have a well-planned maintenance strategy to succeed compared with their competition. A faster, newer machine does not automatically mean that your company will keep a competitive edge. When a spindle breaks down, the company that proactively manages its machine will reduce downtime and expenses, resulting in an increase of productivity. This will significantly boost the company ahead of competitors.
Photos courtesy of Gilman Precision
The process of managing your machine includes developing a machine tool and spindle service program. It is important to establish an effective machine tool and spindle service program to achieve a high level of overall equipment performance. Overall equipment performance is a measurement of performance comprising three factors: asset availability, production and quality level. The following four programs display the different types of procedures used when a spindle goes down. These range from the most basic plan of action to a highly advanced plan.
1. The Emergency Program
You can compare the emergency program to hitting a panic button. If an important spindle breaks down, the company will do whatever it takes to repair that spindle as soon as possible. No matter the expense, the company will have the spindle shipped and serviced with the highest priority. Immediately repairing the spindle reduces downtime, but the costs add up because of the urgency, making it less practical than other programs. Gilman Precision, Grafton, Wis., accommodates this type of program by offering the option of a rush order service.
2. The “First In, First Out” Program
The first in, first out program works as if there is no program at all. There are no precautions taken, such as scheduling routine maintenance checkups. Similar to the emergency program, if a spindle breaks down, it is simply taken in to be serviced. The difference is there is no urgency to fix it. This program may be impractical, especially if the spindle that is down is important. There is no priority put on it when being serviced, which means that it can take weeks or months before it is back up and running. This can put production behind, which can set your company back from your competitors.
3. The Scheduled Program
Routine maintenance checkups are performed when using the scheduled program. The checkups are scheduled based on the previous maintenance records. This program provides the spindle with enough attention to keep the spindle running in good operating condition. However, the program does not take into consideration fluctuating hours of operation, environmental considerations or whether the spindle even needs to be serviced. The problem is, the spindle could be running fine, but time and money may be lost because of unnecessary services.
4. The Spindle “Hotel” Program
The spindle hotel program takes preventive measures by possessing more than one spindle that is exactly alike. The spare spindle acts as a replacement in case the main spindle breaks down. The spare is kept either on-site or at a designated repair facility. The positive to this is that downtime remains low. If the spindle breaks down, the spare replaces it and production does not have to stop to wait for it to be fixed. The downside to this program is that the amount of capital sitting in the hotel could outweigh the convenience of the program. If this is the type of program your company follows, Gilman Precision provides a spindle "R&R" service that allows any spindle to be housed for up to 12 months after being repaired.
The most important consideration to factor in when deciding on a program is the goals of the plant. The program needs to align with the company’s objectives. Deciding which spindle service program is the best fit for your company should not only align with the goals of the company but should be individualized to all your spindles. Monitoring your spindle can save it from unpredictable damage and allow it to maximize its production. Reducing unnecessary downtime and costs can help push you ahead of the competition. If you are questioning what you are going to do when a spindle breaks down, it is time to implement a strategy that will optimize your overall equipment performance.
04/15/2024
04/11/2024
